Reply 16080 of 57737, by FesterBlatz
I got a clean pair of IBM 5x86c 100MHz CPU's from a pretty obscure eBay listing for $19.50 each, free shipping. I shared the eBay listing link here since the seller still has 5 left: Post 567923
They arrived today in perfect shape and work great. They have pretty substantial OEM heatsinks attached with a VERY persistent adhesive tape, but I manged to carefully remove one of them after sticking it in the freezer for an hour to temporarily reduce the hold of the adhesive.
According to the eBay listing they were pulls from IBM Point of Sale machines, and I recognized 88H1052 as a 5x86 part number from one of IBM's last runs of the 5x86. Both are 1996 week 35 stepping 0 rev 5.
The attachment FullSizeRender.jpg is no longer available
The attachment FullSizeRender_1.jpg is no longer available
The attachment FullSizeRender_2.jpg is no longer available
The attachment IMG_1666.JPG is no longer available
Reply 16081 of 57737, by lazibayer
badmojo wrote:
A couple of Audiodrives - the compaq card was a much appreciated gift from Boxpressed, as seen in his excellent wavetable thread […]
A couple of Audiodrives - the compaq card was a much appreciated gift from Boxpressed, as seen in his excellent wavetable thread.
I just bought a one dollar haul that includes the compaq card from eBay. I looked up the data sheet and to my amusement the ES692 chip has so many NC leads... It could be encapsulated in a 16 pin package.
The attachment Screen Shot 2017-03-05 at 12.42.18 AM.png is no longer available
This card reminds me another "similar" card... By similar I meant OEMed for big brands with wavetable.... The IBM S-16FP/L that came with CS9233 wavetable card. MIDI sounds terrible on that combination, but sounds quite nice if I remarry the wavetable card with a Turtle Beach Santa Cruz.
Reply 16082 of 57737, by Tetrium
FesterBlatz wrote:
I got a clean pair of IBM 5x86c 100MHz CPU's from a pretty obscure eBay listing for $19.50 each, free shipping. I shared the eB […]
Perhaps you should've gotten all of them. Have you tried running at 133MHz? 😁
Or at least see if these have 4x CPU multiplier.
My retro rigs (old topic)
Report spammers here!
Reply 16083 of 57737, by Artex
I nabbed the rest last night. Was curious about this myself. 😎 (and I do like Cyrix processors in general).
Reply 16084 of 57737, by Tetrium
Nice to see all of these end up in the hands of Vogoners. Please feel free to let us know your results 😀
Reply 16085 of 57737, by GL1zdA
boxpressed wrote:
Glad to help out a fellow ESS fan! […]
I got this in the mail yesterday. I wasn't aware of a Goldfinch variant with line out and SPDIF jacks already installed. A versatile little card now.
Where have you found it?
getquake.gif | InfoWorld/PC Magazine Indices
Reply 16086 of 57737, by boxpressed
eBay. $15.
Reply 16087 of 57737, by meljor
🤣 ''bigger is better!!''
Reply 16088 of 57737, by Artex
Ageia PhysX - BFG Ageia PhysX 128MB PCI (NOS) (2006)
AMD Athlon 64 FX-55 (ADAFX55ASBOX) (CAA2C) Socket 939 (New Opened Box) (2004)
Reply 16089 of 57737, by sf78
Artex wrote:
http://imagizer.imageshack.us/v2/1024x768q90/924/gEq3UH.jpg […]
Very nice! I was about to swap my 4200+ to 4800+ when I noticed the later was an AM2 socket instead of the 939 I thought it was. 😵
Reply 16090 of 57737, by appiah4
Impulse purchase:
The panel is quite yellowed and there is no remote and connector cable included however, which kind of throws a spanner into my plans.
I was hoping to drop this into my current gaming rig (I currently use AL888..) and also use it for recording audio during LP videos and stuff. But the yellowed panel and lack of cable means I'm second guessing that option, and kind of regretting not going for a ZS for the same price of this ($5.. heh). Anyway, if someone could point me towards what kind of connection cables I need, and guide me as to whether the Audigy 2 is still a good card for Windows 7, I'd be very happy. 😀 I was planning on using a Live! CT4780 for my Tualatin build but if it's not a good idea to use this in a modern PC at all I could just use it in the Tualatin instead, maybe.
Reply 16091 of 57737, by gdjacobs
Just use a 40 pin ribbon cable (not a UDMA66+ 80 conductor version).
Reply 16092 of 57737, by appiah4
The manual explicitly says not to use a PATA cable and that it would cause electrical damage.. I have a feeling it's a load of bullshit, but wouldn't mind clarifying. I've found pictures of the original cable and the only difference from a normal ribbon is that some pins are blocked making sure you can't plug it in reverse or shifted left or right?
Reply 16093 of 57737, by gdjacobs
Yes, you can damage equipment if you plug in with the wrong orientation. That's likely what they're concerned about.
Reply 16094 of 57737, by TheAbandonwareGuy
appiah4 wrote:
Impulse purchase: […]
Impulse purchase:
Be aware that 24-bit recording/output will always be limited to 16-bit over analog (digital unaffected) on those cards due to the fact they aren't 24-bit end to end. That being said I've found the drivers on Windows 7 (at least on most machines, these cards seem to sound slightly different on each machine I try them in) are quite bass heavy and need to be adjusted to hear voices and such clearly. I run one in my media center PC, and with the EQ counterbalance I have set up it sounds quite nice. The recording on mine (Cassette > MP3) was crystal clear as well. If you're recording LPs though you're going to want to wait until you can get a ZS since LPs can take a noticeable advantage of 24-bit recording if you use a proper lossless codec and a decent record player.
Also I believe the front panels from original audigys work for a ZS. But double check because I can remember if they changed there front panel connector with the ZS or the XFi series. One of those 2 broke compatibility with older panels.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 16095 of 57737, by kikenovic
A Sidewinder Precision Pro and an intellimouse for my "97 rig". After installing the drivers, the joystick seems to be working great under the control panel test but it's not working on Flight Sim 98. Will have to research more on that. Back in the day I played FS98 using a generic 4 button gamepad, then a Gravis gamepad pro and keyboard.
Reply 16096 of 57737, by yawetaG
Just bought a Pioneer DVR-545H DVD/harddisk recorder for 15 Euros at a local store, unfortunately no remote meaning I can't access the recording features and set-up. 160Gb harddisk (not tested yet), multiple AV ins/out including HDMI, 2x SCART, 3x Composite/S-video...very dusty unfortunately. Plays DVDs just fine though, and I've already found a generic remote that supposedly works with the thing for 10 dollars shipped from China...
The store also had 5(!) Toshiba 486 laptops for 7.50 Euros each (bit expensive), no power supplies. Since the things are heavy like hell and I had come on foot I skipped them for now.
Edit: Laptops are T1900 and T1910 laptops, 486SX 20 MHz and 33 MHz, couple of hundred Mb harddisks each.
Reply 16097 of 57737, by Lukeno94
If any of those floppy drives were good, I could do with one for my T1950. Although I wouldn't want to kill working systems...
Reply 16098 of 57737, by yawetaG
The problem is that I don't have a power supply to test them with (they were tested by the store..how? no idea, but they are supposed to work...) and there is only 2 days of warranty on purchases...so I either buy a power supply and have the risk they get sold before I receive the power supply, or buy them and may discover I have a bunch of non-functional laptops once I get a power supply. So it's unlikely I will buy them...
Edit: If one of my fellow Dutch members wants to know the address of the shop (in Zuid Holland), PM me.
On the DVR side, it's very dusty inside, but the hard disk (and therefore HDMI) works. The hard disk (Seagate) and DVD drive are pretty much standard PC parts, Ultra ATA 133. I'll probably try to get a remote for it, it seems to be set up for mono sound only (gotta change that). Then I'll use it until it breaks down and recycle the (steel!) case for a home-made media center.
Reply 16099 of 57737, by Skyscraper
I just bought a bare (not even an I/O shield) Socket 939 motherboard for 80 euro!? 😳
In my world there are only two Socket 939 motherboards that are worth that kind of money, three if we include the ASUS A8N32-SLI Deluxe but I already have ... enough ... of those. By the way there is an A8N32-SLI motherboard on Ebay for $45 at the moment which is a good price, untested but it looks good from what I could tell.
Does anyone want to guess what motherboard I bought? As a hint I can say that it's NOT the bright planet! 😁
