Reply 166 of 196, by mothergoose729
Ryzen R5 3600 @ ~ 4.15ghz
16GB DDR 4 3200 CAS 16
Windows 10 Pro x64
Speedsys normal: 625430 parrots, 231.9 XT
Speedsys dynamc: 2800000 parrots, 1038.2 XT
Doom normal: 79.6fps/938 realtics
Doom dynamic: 290.6fps/257 realtics
Quake_SW 800x600: 59.2, 58.9, 58.9
Quake_SW 320x200: 183.6, 183.9, 183.3
A note on precision boost 2.0 - it oscillates clock speed between 4.05 and 4.2ghz constantly. 4.15ghz is pretty close to the average. How long and how often it reaches top speed depends on cooling and the power limits set in the bios. I have the power limits set to max, which means the motherboard determines the power limits. Different board could set a different limit, and better cooling lowers power consumption at the same voltage and clock speed, ect. I have a really good air cooler (Noctua NH-D15) and a decent board (ASRock B450 Pro4), so my setup could be + / - 5% compared to someone else, but probably represents the upper range for this particular chip.
