Reply 17460 of 31264, by Bruninho
appiah4 wrote on 2020-12-10, 10:24:
Actually that's wrong, as it should have been: […]
Bondi wrote on 2020-12-10, 10:20:
brief history 😁
Bruninho wrote on 2020-12-10, 10:14:
Windows 3.11 = Great!! Windows 95 = Good Windows 98 = Very good Windows 2000 = Awesome Windows Me = Garbage Windows XP, Vista, […]
Windows 95 = Good
Windows XP, Vista, 7, 8 = Sh*t
Windows 10 = Even with all the Tylenol in the world, I cannot avoid the headache that is to use this pile of sh*t. Wait, I can. Just uninstall it.
IMO Microsoft stopped doing good stuff after 2000.
3.0 Good
3.1 Shit
3.11 fWG Good
Win95 Shit
Win98 Good
Win98 Shit
Win2K Good
WinXP Shit
Win2K3 Good
Win Vista Shit
Win 7 Good
Win 8 Shit
Win 8.1 Good
Win 10 Shit
Pretty close, I could agree
JOBS, Steve.
Reply 17461 of 31264, by xcomcmdr
Shreddoc wrote on 2020-12-10, 10:41:
Windows was a good name choice, for something that's never had doors, walls, a roof or a floor.
But Windows already had Gates.
Reply 17462 of 31264, by TechieDude
As much as I prefer mostly *nix OSes, I have to disagree, ME and Vista weren't really that bad, especially the latter was crippled by shitty drivers and old hardware that was released in the early 00's. Basically, manufacturers went out of their way to provide the absolute minimum, and didn't make drivers that actually worked with the then-new WDDM, among other things. By the time 7 was released, Vista run just as well, provided you had decent hardware.
Reply 17463 of 31264, by Dmetsys
It took two Service Packs to fix all the issues with Vista. I wouldn't be blaming the hardware, especially if you had much more than the minimal requirements to use it. Service Pack 1 brought in some kernel fixes to resolve the memory usage/disk paging problems that plagued Vista. SP2 added further stability. The same issues were found in Server 2008, and resolved in Server 2008 R2, which was based on the Windows 7 kernel.
Can't say that I was wasn't one of many that eagerly waited for the release of Windows 7. I was using XP x64 at the time, as I detested Vista with a passion.
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 17464 of 31264, by xcomcmdr
Vista was butt-ugly too. So much dark colors everywhere. Windows 7 finally introduced more colors. And then the Big Boring Flat Design nutjobs came along...
Reply 17465 of 31264, by justmex
Standard Def Steve wrote on 2019-08-05, 16:36:
I just found something that the G4 is really good at: video playback!. In fact, it's so good at software H.264 playback--a very […]
Sedrosken wrote:
Yeah, it's kinda sad to mess with PowerPC machines and not be able to see the hype even compared to its comtemporaries. I can still browse the internet okay on a Pentium 4 -- it's not the quickest experience ever by anyone's imagination, but it blows even a dual-G4 machine out of the water. And makes less heat to boot! I think you're on the right track though by fetching a copy of Tiger for it -- Leopard was even considered slow for the time on a lot of G5 systems if I'm remembering correctly. Meanwhile Tiger ran acceptably on my 800MHz iBook G4 with only 256MB of RAM.
I just found something that the G4 is really good at: video playback!. In fact, it's so good at software H.264 playback--a very FPU intensive task--that I'm starting to think the poor web and gaming performance is just due to poorly optimized software, rather than a weak CPU. After all, the games I've tried on this machine (Doom 3, Quake 4, UT2004) were ported from Windows, and who knows how well.
With CorePlayer running on Leopard, I loaded up the regular 720p and 1080p MKV files that I use for benchmarking x86/Windows H.264 decoding performance. The dual-G4 1.25GHz machine not only played the 720p file flawlessly at only ~40 CPU usage, but actually managed to handle the 1080p file as well. That absolutely floored me. I was not expecting that at all. It completely outclasses the PIII-S machine, and in fact rivals my Athlon 64 running at 2.64GHz! I've read that CorePlayer uses AltiVec (the PowerPC equivalent of SSE2) quite heavily, and it shows!
Here are some comparisons to some x86 processors (the x86 stuff was tested using CoreAVC in MPC-HC under WinXP SP3)
H.264 1280x720 (5mb/s, Level 4, 24 fps):
Dual PowerPC G4 @ 1.25GHz (167MHz FSB, 2GB DDR-333, 256K fullspeed L2, 2MB external L3 cache per processor): ~40% CPU
Single Pentium III-S @ 1.63GHz (155MHz FSB, 2GB DDR-310, 512K fullspeed L2 cache): ~90% CPU
Single Pentium 4 @ 2.66GHz (533MHz FSB, 2GB DDR-333, 512K fullspeed L2 cache): ~80% CPU
Single Athlon 64 @ 2.64GHz (960MHz HyperTransport, 2GB dual-channel DDR-440, 1MB fullspeed L2 cache): ~35% CPU
H.264 1920x1080 (14mb/s, Level 4, 24 fps):
Dual PowerPC G4 @ 1.25GHz (167MHz FSB, 2GB DDR-333, 256K fullspeed L2, 2MB external L3 cache per processor): ~92% CPU
Single Pentium III-S @ 1.63GHz (155MHz FSB, 2GB DDR-310, 512K fullspeed L2 cache): 100% CPU, unwatchable
Single Pentium 4 @ 2.66GHz (533MHz FSB, 2GB DDR-333, 512K fullspeed L2 cache): 100% CPU, unwatchable
Single Athlon 64 @ 2.64GHz (960MHz HyperTransport, 2GB dual-channel DDR-440, 1MB fullspeed L2 cache): ~88% CPU
Edit: However, CorePlayer may be taking shortcuts to speed decoding performance. On the G4, I noticed some artifacting in a couple of very high-motion scenes. On the x86 machines, these scenes were completely clean.
Interesting! Do you have some gaming benchmarks of your Macs(G4 vs G5)?
Reply 17466 of 31264, by ragefury32
Dmetsys wrote on 2020-12-10, 04:08:
Got the old T2155CDS up and running. Had to install DOS 6.22 on my Contura 400C, as the T2155CDS didn't come with a floppy drive. Transferred the benchmark apps, drivers, and Windows 3.11 installs using my IDE to USB converter cable. The screen is in need of replacement due to bad shadowing. I might have to explore options for a CDT (Active TFT) replacement.
Yeah, that dual scan passive matrix screen is just so much hot garbage, and the passage of time does nothing help it out whatsoever. Swap it out with something from a 2150 or 55CDT. Overall it’s a decent machine, if not a bit slow.
Reply 17467 of 31264, by creepingnet
Versa M/75's case was crumbling like Feta Cheese so I moved to the P/75 (Pentium 75) version instead and TBH, not quite a bad change at all, actually, quite nice as I now have SoundBlaster Audio on-board. Seems the P/75 is a bit better built and not quite as cracked. Also, I was expecting poor battery life - nope, battery life is about the same, maybe a tad better. I played Dragon Warrior on it in NESTICLE off battery, then played Dragon Warrior II, then a round of Hoyle Solitaire....and it was still going with 2 out of 4 bars of battery life.
As for the Versa M/75.....hehehe....it's not really "Dead". I've got a bit of an idea to make my own custom case and exploit some design elements to make a much better structure. Who knows, maybe I'll start buying/taking donations up old broken Pentium and older laptops to convert into killer FreeDOS rigs. I've got some ideas (using USB LiIon Battery packs, Increased WiFi Range, possibly modding to use WPA using a bridge on board the case.....lots of ideas - modern LCDs with LED backlights in a bigger size, adding OPL support via the LPT Port that never gets used).
So we'll see where this goes.....maybe It'll be a one time thing, maybe two time (I've got an extra motherboard and power board that needs minor repair in my closet for an 40E/50E/75E)...maybe I'll just start swiping up all the broken stuff on e-bay that'll never sell because of hinge/case/cracking issues....who knows.
~The Creeping Network~
Reply 17468 of 31264, by TechieDude
Dmetsys wrote on 2020-12-10, 14:48:
Same thing with XP, except Vista wasn't released within 3 years... Plus, I mentioned that drivers for Vista sucked at the time.
Reply 17469 of 31264, by Dmetsys
TechieDude wrote on 2020-12-10, 21:07:
You can continue to mince words all you want. The Service Packs for XP contained Windows Updates and the Windows Activation components. No kernel rewrites. Vista had a complete kernel rewrite in SP2.
Again, if the kernel isn't stable, nothing will run stable including drivers.
Reply 17470 of 31264, by Bruninho
xcomcmdr wrote on 2020-12-10, 15:11:
Hey, I like flat designs. I do not like XP bloody colorful design, it looked like it was designed by Toys'R'Us for childrens.
JOBS, Steve.
Reply 17471 of 31264, by TechieDude
Dmetsys wrote on 2020-12-10, 23:04:
You can continue to mince words all you want. The Service Packs for XP contained Windows Updates and the Windows Activation components. No kernel patches. Vista had a complete kernel rewrite in SP2.
First of all, you start accusing me of 'mincing words', whatever that means. Second, complete kernel rewrite? Where did you even get that from? No offence, but that sounds like total BS. A complete kernel rewrite would be way more trouble than it would be worth, especially via a Service Pack for one of the most hated OSes of all things. That hasn't been done since NT 3.1 for a few reasons... As for XP, that wasn't really all that big of an upgrade from 2000 to need anything huge, but it was quite hated pre-SP1. Its kernel also got a patch for DEP in SP2 if I recall correctly...
Reply 17472 of 31264, by Caluser2000
I luv it when nerds fight each other. It's great entertainment. I stopped using MS windows completely about the time Vista showed up . XP was fine after SP1 but still had to do the regular maintenance. Win2k was never marketed to the average home user, XP was. You can customize XP to look how every you want it to look with 3rd party tools. I would imagine the same went for Vista onwards.
Anyway sorry to interrupt. Carry on.......
Reply 17473 of 31264, by Dmetsys
Caluser2000 wrote on 2020-12-11, 00:00:
I luv it when nerds fight each other. It's great entertainment. I stopped using MS windows completely about the time Vista showed up . XP was fine after SP1 but still had to do the regular Win2k was never marketed to the average home user, XP was. You can customize XP to look how every you want it to look with 3rd party tools. I would imagine the same went for Vista onwards.
Nah, just more like who actually used it vs the 'I read it sucked' point of view. It's always easy to trump these kinds of debates.
Reply 17474 of 31264, by Caluser2000
Dmetsys wrote on 2020-12-11, 00:18:
That is certainly true On XP I just selected the legacy/classic theme and HEY PRESTO!! the default theme was gone. It took a few seconds so hardly a hardship.
Reply 17475 of 31264, by Caluser2000
Also forgot to mention that XP had quite a few EOL extensions because Vista was not being adopted as MS would have prefered by both home users and business users. Same thing happened to Windows 7.
Reply 17476 of 31264, by bjwil1991
foil_fresh wrote on 2020-12-10, 10:15:
A rather ad-hoc cooling solution for a GeForce4 Ti4200-8X (winfast A280LE) that had a busted fan.
I realise that the case fan is pushing air away but its pretty drafty and the heatsink is never hot to touch so it seems fine. The sensor was saying 52deg c after running 3dmark 2001 a few times.
Glad it works, bought it in a combo P4 2.4 and intel 845 mobo deal for cheap (too cheap, i think he didnt know what kind of card it was due to the odd labelling), but its gone into my athlonxp 2200+ / asus a7n8x-x nforce board.
That is amazing. I gotta do that for my Ti4400 AGP and good thing I have plenty of case fans to install.
I tested the Austin PN/312 TFT laptop that the seller said it "won't light" and when I plugged in the switching power supply set to 9VDC 2.5A, it turned on. The issues that are present are a dirty/oxidized/corroded power board that does work to a point, broken right hinge (will use epoxy to fix it), and the floppy drive that suffered from the belt plague. The display is in amazing shape and it will get more inspections and a new CR1225 battery holder with wires and the battery.
Currently looking for an NEC NL6448AC30-07 TFT display so I can install one in the AMS laptop and surprisingly, the 5x86-P75 3.3V CPU works in the AMS laptop, but I need to find a way to set the CPU to 133MHz (4x clock speed). The Austin has 20MB RAM and a ceramic Intel i486 DX4-100 CPU.
Reply 17477 of 31264, by creepingnet
bjwil1991 wrote on 2020-12-11, 05:25:
Those NL6448AC30-XX screens are what my NEC Versa M/75 and 40EC use (my P/75 is an NL8060 model of some kind as it's 800x600 - the first four digits are the first two of each parameter of the screen resolution, but those ALSO used the 640x480 screens....I think it was the HC models). The last two numbers after the hyphen should not matter as they are all pretty interchangeable with each other. My NL6448AC30-10 out of the M/75 was pretty terrible and washed out (looks like a bad DTSN LCD), so I put the NL6448AC30-06 I had in my 40EC in there when the M/75 still had a case (it's case literally started to fall apart - bad - I'm using the P/75 now).
I find these screens on e-bay, sometimes for a decent price. It seems not just were they used in the NEC Versa line of laptops but they also were used in a lot of industrial equipment and embedded apps stuff and seem to still have some need in that area.
Reply 17478 of 31264, by bjwil1991
Yeah and I was attempting to connect the display to my AMS laptop and that didn't work out too well as I forgot the BIOS is strictly DSTN on the AMS.
Currently been cleaning the Austin laptop and preparing to fix the broken hinge and I need to know which method is better to fix the hinge issues: longer screws (not damaging the chassis) or epoxy.
Reply 17479 of 31264, by HanJammer
Caluser2000 wrote on 2020-12-10, 06:10:
Bruninho wrote on 2020-12-10, 01:38:
With me its the opposite. The more I use the older Windows 9x versions, the more I hate the actual version.
Hah?
Windows 95 = Good
More like:
Windows 3.11 and everything before = Garbage
Windows NT 3.5, 4.0 = Pretty good
Windows 95 = Not so good
Windows 95 OSR2 = Pretty good
Windows 98 = Not so good
Windows 98 SE = OK
Windows 2000 = Good
Windows Me = Not so good
Windows XP (after SP2) = Great
Windows Vista = not so good
Windows 7 = Great!
Windows 8 = Not so good
Windows 8.1 = Pretty good
Windows 10 = Amazing
And there are also all sorts of Server versions which are usually pretty good.
