Reply 1760 of 1953, by LSS10999
Rawit wrote on 2026-03-26, 08:04:
The Wavetable Pi is also noisy in my experience. Had those "computer thinking" noises. Tried some fixes from the GIT repository but no cigar.
I assembled my own WavetablePi boards in a similar manner to this, just that I additionally moved the caps to the other side as well, leaving only resistors whose height is negligible on the side of wavetable connector, eliminating any possibility of conflict with components on sound cards.
The resulted board would be much thicker that will occupy the adjacent slot, but it's not an issue for ISA sound cards plugged into dISAppointment.
I'm not sure about the possible causes of the noises regarding WavetablePi... perhaps my ears are not sharp enough to be aware of any. It's possible this different way of assembling the board might have resulted in a different, less noisy atmosphere.
Reply 1761 of 1953, by appiah4
NeoG_ wrote on 2026-03-27, 00:30:
Makes me glad I paid the extra for a WP32 😬
WP32 is amazing good in terms of output clarity, yes.
Reply 1762 of 1953, by Rawit
Linoleum wrote on 2026-03-26, 23:49:
Especially when you have an i2c oled screen installed I found...
Removing that was the first thing I tried. But then I noticed that the noise was different using the SF2 mode vs the MT-32 mode so it was coming from the Pi.
YouTube
Reply 1763 of 1953, by Nitram78
Could moving the wavetable card away using a flat cable help?
Reply 1764 of 1953, by appiah4
Nitram78 wrote on 2026-03-27, 10:11:
I doubt it, this sounds like an issue with filtering and shielding on the audio channels. Someone like @dreamblaster @LABS or @keropi would probably explain better.
Reply 1765 of 1953, by Linoleum
The way I ended up taming the noise was by doing two things:
A) bumping up the gain in the config file, and
B) lowering the MIDI output level in the card’s mixer.
With that combo, the noise floor is no worse than what you’d get from a typical Sound Blaster.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 1766 of 1953, by 919guy
Flywheel wrote on 2025-09-12, 15:56:
Has anyone tried or have had success simultaneously using a USB mouse and CD-ROM emulation through a powered USB hub? I have tried with a couple of modern USB hubs but do not currently have a 1.1 hub to test with. I have been able to use the mouse functionality through one of my two modern hubs but neither would detect the USB sticks as a CD-ROM. Both work just fine when plugged in directly to the Picogus.
I've tried that with different USB hubs, too. But the USB mouse and a USB flash drive for the CD-ROM function don't work at the same time. In single use you can switch them around any time. But when both are plugged in, neither of them works anymore.
Reply 1767 of 1953, by polpo
I didn't have much issue with simultaneous mouse and USB flash drive on a hub myself, but Delphius's fixes should help that for those who are having problems. It'll be out in a new firmware very soon, in addition to Sound Blaster 16 and OPL3 support.
creator of PicoGUS and PicoIDE
Reply 1768 of 1953, by DJNW
While we're on the topic of the WavetablePI, I've noticed mine has a bit of a sag - anyone else propped theirs up at all?
Reply 1769 of 1953, by NeoG_
polpo wrote on 2026-04-02, 15:39:
Will the SB16 DSP follow the hardware closely including the faulty SB Pro stereo issue or was that fixed in the SB16 DSP that was used as a base for the new firmware?
DJNW wrote on 2026-04-02, 18:10:
I folded up some card stock into a square tube and stuck it between the wavetable board and the PicoGUS PCB using some low strength double sided tape to keep it straight
Reply 1770 of 1953, by polpo
NeoG_ wrote on 2026-04-02, 21:52:
SB Pro stereo works fine, unlike on a real SB16. The emulation not a 1:1 emulation of a specific DSP in that it's not running the actual 8051 code - think more DOSBox-like. You'll be able to set the DSP version using pgusinit, and that could possibly change different behavior, but right now all that does is change whether the "speaker on" command is honored or not, because the SB16 ignores that command and some titles don't bother with that command. The main target is to have an "SB16" that "just works" no matter if you use it as an SB 1.5, 2.0, Pro 2.0, or SB16. So that means an MPU with no hanging note bug, supporting SB Pro stereo, etc.
Reply 1771 of 1953, by Pickle
what about the high dma, does it have to be shared and the game has to support assigning the same dma?
Reply 1772 of 1953, by polpo
Pickle wrote on 2026-04-02, 22:51:
It works just like a ViBRA 16XV card - there is no high DMA. 99% of the time you can just set the high DMA to be the same as the low DMA - it's not "shared" per se, it just tells the game to use the 8-bit DMA for 16-bit sound. Some games like Duke3D need some coaxing to use a low DMA for 16-bit sound, but it's possible.
Reply 1773 of 1953, by NeoG_
polpo wrote on 2026-04-02, 22:39:
Left field question, I have been thinking about putting an RS232 dry contact relay board to control various stuff inside one of my boxes (like a 15khz scanline emulator). One of the limitations I have is that sound blaster is not good on IRQ2/9 (many games don't allow the IRQ) and MPU401 intelligent mode requires IRQ 2/9. SoftMPU can't translate the IRQ either. Do you think the PicoGUS card would mind having the IRQ jumpers externally controlled so I can change the IRQ assignment on the fly while the system is operating but idle?
Reply 1774 of 1953, by polpo
NeoG_ wrote on 2026-04-02, 23:23:
I generally wouldn't recommend this because the IRQ jumper carries the actual IRQ signal. Depending on how far out you extend it you may run into issues. Or maybe it'll be fine, who knows. Changing it on the fly shouldn't be a problem.
One thing you should try is CTS SwapIRQ: it's a TSR that redirects one IRQ to another. It's worked on every single game that requires IRQ 2/9 with MPU-401 intelligent mode that I've tested. The only downside is that it is very annoying nagware. I've thought that it's likely due for a modern rewrite as it can't be too hard to implement. There's a Vogons thread about it here: SwapIRQ
Reply 1775 of 1953, by NeoG_
polpo wrote on 2026-04-02, 23:52:
I came across CTS SwapIRQ while looking at my options, but I don't think I could handle the nagware aspect as a perment solution. If the registered version could still be purchased that would be a much easier option.
I'd probably end up sticking a 5v relay (e.g. Pansonic TQ2SA-5V high frequency relay) to the back of the PCB just above the jumper block to switch between two IRQ states and extend the 5V control back to the RS232 controller. Hopefully with only a couple of centimetres of additional travel the signal integrity should be good enough. I'm also going to try the same thing with the motherboard's FSB jumpers.
Reply 1776 of 1953, by Shreddoc
NeoG_ wrote on 2026-04-03, 00:34:
I've made a simple, manual switching harness for SS7 motherboard FSB and multiplier jumpers in the past. No issues were encountered, and those jumpers did not care about wire length. The goal was merely so I could set those externally while the machine was powered off, however - nothing on the fly.
These days I tend to connect a Throttle Blaster to my main S(S)7 system, as a bit of a godmode speed dial. They work well as a semi-permanent installation on a particular machine. Just one of many options.
Reply 1777 of 1953, by NeoG_
Shreddoc wrote on 2026-04-03, 01:36:
Did you make a youtube video about it? I remember seeing a video of someone making an FSB switchblock a while ago and thought they did demonstrate it switching with the system on
Reply 1778 of 1953, by Shreddoc
NeoG_ wrote on 2026-04-03, 08:56:
No Youtube video, though I might have posted about it on Vogons before. I'm sure other people have done similar endeavours, probably more sophisticated than mine, which was merely a couple of DPDT switches in a drive bay panel configured to allow 4 combinations of FSB/Multiplier. I never thought about testing it live before.
Reply 1779 of 1953, by myne
Silly question for the experts. I've been looking at the schematic, and if someone wanted to plug it directly into the lpc bus, you strip out the isa, it looks like the whole thing amounts to a pico, dac, and jack.
I'm not entirely sure what the midi +jack is for in the context of playing games. Possibly those too.
That... Can't be all of it. Can it?
I assume it would require a bunch of work on the software side though.
I built:
