Hardware you wish you'd never bought.
Reply 180 of 219, by GemCookie
UCyborg wrote on 2025-04-04, 19:22:
GemCookie wrote:
I recently ditched my X-Fi, since the driver CD is useless on Windows 11, while Creative want me to sell my soul to SatanGoogle in order to download newer drivers.
Can you explain that part?
The drivers from the CD do not install on Windows 11. Creative's website asks to solve a reCAPTCHA challenge (served by Google) before any drivers can be downloaded.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 181 of 219, by badmojo
GemCookie wrote on 2025-04-04, 19:37:
Daniel K's driver pack is better in my experience anyway, and no strings attached.
Reply 182 of 219, by jakethompson1
When I was 10 I convinced parents to have a person in the yellow pages come and do a few upgrades (including 16MB to 80MB RAM) and I asked for a zip drive. Got a stupid parallel port Syquest drive instead.
Reply 183 of 219, by cyclone3d
Don't think I have posted in this thread yet... but if I did it is probably the same thing I am listing now...
1. Matrox Mystique. Had it for a couple days and then took it back due to suckage.
2. Voodoo Rush. Was the upgrade from the Mystique.
Took it back after a couple days due to suckage.
Replace it with a Banshee and that was a lot better. Upgraded to. V3 and then a V5 layer on.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 184 of 219, by ncmark
IBM DTLA-307030 o
One of the deathstars
It never failed but I never trusted it, wound up throwing it out and getting a seagate
Reply 185 of 219, by ncmark
MAYBE anything K6-2. If I knew then what I know now, I would have gone celeron (the latter socketed ones with cache)
Reply 186 of 219, by Spark
Bought an AWE64 Gold, hardly used it. A cheap soundblaster clone would have served me just as well. Gave away that PC to serve as an office PC. AWE64 probably in landfill now. What a waste.
Reply 187 of 219, by Intel486dx33
Move Forward NOT Backwards
Rate of Decay
People want to revisit computers from 80’s and 90’s
But Capacitors and Electronics don’t last forever.
They go bad over time and solder joints break too.
Don’t invest your MONEY in used old electronics unless you know what you are doing and are
Willing to accept allot of bad components.
You don’t know the history of these components and if they have been hacked, abused, suffered electrical damage, misused, etc.
Better to buy NEW good components with a Warranty.
I have allot of old electronics from before 2010 and allot of them are starting to go bad now.
Reply 188 of 219, by schmatzler
Intel486dx33 wrote on 2025-04-11, 16:56:
You mean those modern devices that conveniently fail just after the warranty expires?
Devices that can't be repaired due to missing datasheets or (if the manufacturer is especially evil) components that are married cryptographically?
Doesn't seem like a great alternative, honestly.
Reply 189 of 219, by Intel486dx33
schmatzler wrote on 2025-04-11, 17:48:
You mean those modern devices that conveniently fail just after the warranty expires? Devices that can't be repaired due to miss […]
Yes, ISA cards are the Easiest to repair and most resilient.
Reply 190 of 219, by darry
Move Forward NOT Backwards Rate of Decay […]
Rate of Decay
You don’t know the history of these components and if they have been hacked, abused, misused, etc.
IMHO, as with many things in life, YMMV and there are few absolutes.
Newer is not universally better. A lot of the newer stuff is built to a (low) cost, designed to run too close to thermal limits (reduced longevity) and harder to open, repair (multi layer boards, BGA components, custom chips, cryptographical locks, etc) and have a short design life because they are considered disposable once the warranty expires. Manufacturers likely hope a product will fail after the warranty ends, but not immediately after as not to generate ill will about the brand , but not too long after in order to have a chance at another sale.
I buy both new and old stuff, but I am selective.
I will take chances on older stuff that either is within my abilities to upkeep/repair OR cheap enough that I can take a chance and take a calculated risk. I gauge risk based on reputation, avoid thermally compromised designs (very high end CPUs and GPU have been very power hungry in recent years) and take chance on something that may have been ridden hard and put away wet (but hopefully hasn't).
Heat and high power draw arealso the enemy when choosing new stuff, so I choose accordingly. I try to overspec things like cooling, power delivery, write endurance and performance requirements (to a reasonable point).
I have found, so far, that modernish stuff (bought new), can be quite reliable too. I have drives, PSUs, motherboards, etc that have been running non stop for 6 years or more.
Whether one's hardware is old/retro or new(ish), heat and thermally induced mechanical stress are the enemy. Home gateway routers, external drives, TVs, all-in-one/mini/laptop PCs, settop cable boxes, for example, are some iyf the devices most prone to have been designed with little regards for heat management. Choosing better designed and/or less energy hungry ones (or modifying the cooling) can go a long way in having electronics last well beyond the warranty timeframe.
I haven been trying to apply this approach for about 20 odd years, and my electronics rarely die or need repairs before I choose to upgrade them.
Reply 191 of 219, by Intel486dx33
Also, Always use Surge protectors with power switches.
Allot of Cities around the world have not had good electrical service provider infrastructure.
Many electrical power surges and spikes, Blown transformers, lighting strikes, black outs, etc.
Reply 192 of 219, by darry
Intel486dx33 wrote on 2025-04-12, 09:24:
And replace surge protected power switches every few years as the MOV component wears out silently as it absorbs surges.
An actual line conditioner offers even more protection. AFAIK, using a quality line-interactive topology UPS can offer a similar degree of protection against voltage fluctuations and possibly againt line noise.
Reply 193 of 219, by emu34b
New small regret: buying antennas and an intel Mini PCI WiFi card. I'm sure they work fine, but I was getting those for my Sossaman board, only to find out that slot on the board isn't Mini PCI at all.
And been through even more 2 GB DDR2 sticks. I've settled with 10 GB. Many ECC errors and hangs when it attempts to display anything other than hardware text mode. 10 GB is still plenty for a PC like this though.
Reply 194 of 219, by Barley
I bought a GeForce3 Ti200 that could not complete a run of 3DMark 2001 SE.
Reply 195 of 219, by BitWrangler
emu34b wrote on 2025-07-02, 18:51:
A lot of mini PCI wifi cards aren't mini PCI either, they're USB in that form factor, so you can bodge them to USB ports/headers.
Reply 196 of 219, by darry
BitWrangler wrote on 2025-07-02, 21:45:
Do you mean mini-PCIe ones ? I don't recall ever seeing mini-PCI ones that the were USB, but I have not seen that many to begin with, TBH.
Reply 197 of 219, by emu34b
darry wrote on 2025-07-02, 22:01:
(replying to both)
The slot on my Tyan board is a TARO-DIMM or something like that. It's like a RAM slot more than a Mini-PCI, which is what I thought it was. I looked into it and it's mainly for like, mezzanine cards to add SATA and SCSI. The SATA one is supposed to be M8110 but I'm not hurting for SATA ports and I ain't paying $100+ for something like that, haha.
Reply 198 of 219, by Dothan Burger
I think I spent $100 on this Socket A heatsink.
The attachment IMG_9047.JPG is no longer available
Reply 199 of 219, by gerry
Dothan Burger wrote on 2025-07-02, 23:32:
it looks interesting though, did it work any better than a more typical alternative? i guess it's all about airflow from the look of it. Actually looks like something an engineering boss might have on his desk to recall the times they actually did the engineering...
