Reply 180 of 421, by bjwil1991
carlostex wrote:
Hi again bjt!! […]
Hi again bjt!!
One question:
I took a look into the source code in the MIDI.C file and i'm wondering if you could add a new switch for better compatibility for the Yamaha FB-01. The only thing the switch needs to do is to chande the constant SYSEX_SIZE to something like 8192. From what i could understand from this thread: IBM Music Feature Card/Yamaha FB-01 such value should give SoftMPU better compatibility for the FB-01. Maybe just throw an if else type condition to define the SISEX_SYZE.
I would try this myself but i would have to download the proper compilers to build SoftMPU. Let me know if it's a viable option to include such an option for a new SoftMPU version, or maybe you can give me some proper links to download all necessary stuff to compile, and i'll change the source code myself.
Here's the compiled SoftMPU version with the updated SYSEX_SIZE from 1024 to 8192
Hope this helps. Plus, when I updated the SYSEX_SIZE from 1024 to 8192, EA Sports NHL Hockey 95 works with the MT-32. For some odd reason, the game requires a higher SYSEX_SIZE. In DOSBox, it works, but in SoftMPU, it doesn't work, unless your running Windows 3.11 and in the MS-DOS menu.
Edit: File removed: changing the build version for less confusion.
Reply 181 of 421, by bjt
Hi bjwil1991
Please could you recompile with a version number that makes it clear it's a customised build, to avoid future confusion.
This change nearly doubles SoftMPU's memory footprint, so it would be nice to get it working as a command-line option.
Reply 182 of 421, by bjwil1991
bjt wrote:
Hi bjwil1991
Darn, I knew I forgot something...
Reply 183 of 421, by carlostex
Hey bjt, will you work on a version with a command line option?
Reply 184 of 421, by bjt
Had a quick look yesterday and it should be possible.
Reply 185 of 421, by carlostex
Cool, i thought so too! I'll be waiting for the next release and provide some feedback!
Reply 186 of 421, by bjt
Cool, I think I've just about got it now. Do you have an FB-01 to test?
Reply 187 of 421, by bjt
If anyone would like to test this I've attached a version below. Please don't distribute this, an official release will follow shortly 😎
The new command-line switch is /LARGESYSEX.
Reply 188 of 421, by Cloudschatze
Why not just remove the SysEx string-size limitation from SoftMPU entirely? It's my understanding that DOSBOX' self-imposed limit is arbitrary to begin with (corresponding to the buffer size), and isn't reflective of an actual MPU-401 besides.
Reply 189 of 421, by bjt
The larger buffer bumps up conventional memory usage from 8K to 17K, so if it's only needed for the FB-01 it's best to keep it optional.
Reply 190 of 421, by Cloudschatze
This is going to sound ignorant, but is the I/O such that a larger buffer is really needed though? The MPU-401 itself only has a 1700-byte buffer.
Reply 191 of 421, by carlostex
I tested with a FB01 and now Silpheed plays the music correctly. I tested Space Quest III and besides only the first SYSEX getting fucked up, the rest goes very well and plays correctly. Awesome.
I'll try to test more games.
Reply 192 of 421, by Great Hierophant
In DOSBox compiled with an 8,192 byte sysex buffer size, you have to send the sysex twice (by starting the game, exiting and restarting the game) to only get dump/received! on the second attempt. Is it the same with the game you tried?
Reply 193 of 421, by Cloudschatze
Would someone mind compiling either DOSBox or SoftMPU with the SysEx size restriction removed entirely, and with a fixed, 1700-byte buffer?
Reply 194 of 421, by carlostex
I didn't need to exit and start the game again.The first MIDI message does make a dump/error but a dump/received will follow immediately. If you don't mind
the first couple of garbled notes before the sierra logo shows up, the rest of the music plays fine and polyphony seems to be quite correct.
Reply 195 of 421, by bjt
Not at all 😀 DOSBox's MIDI code works by buffering each message in its entirety before sending it. In the case of SYSEX this means a buffer large enough for the largest SYSEX message.
This allows some cool stuff like discarding invalid SYSEX and the MT-32 SYSEX delay feature. In the case of the delay feature SYSEX can be buffered (transparently to the game) while any delay is counting down. This is good because we don't want to pause the game or cause it to give up sending.
However, it gives rise to this problem with FB-01 SYSEX (how come they're so big anyway?)
How about we keep the 1KB buffer, but just flush it out to the hardware when it becomes full? That would allow arbitrary-length SYSEX without too many changes to the existing code.
Reply 196 of 421, by Great Hierophant
I tried it with the SYSEXFLUSH version of SoftMPU and the new /largesysex parameter. The first time I start a Sierra game with the FB-01 driver, the unit reports dump/error then dump/received. If I exit the game and restart it, all I get is dump/received. This behavior coincides with the behavior described years ago : IBM Music Feature Card/Yamaha FB-01 (post 8 on that page)
Thus the workaround continues to work, but it would really be nice for SoftMPU and DOSBox to get it right the first time, like a real MPU-401. There must be some data the driver is sending that causes some issue the emulated MPU-401 .
Reply 197 of 421, by bjt
Just to confirm, does the workaround behaviour you describe above still happen with the DUMPSYSEX version without using /LARGESYSEX?
Reply 198 of 421, by Great Hierophant
I never tried the DUMPSYSEX version, which I believe you may have posted and removed. If DUMPSYSEX just increases the sysex buffer size to 8,192 bytes, then it probably will behave exactly the same. The sysex transfer to the FB-01 will never complete without the /LARGESYSEX option.
Reply 199 of 421, by bjt
Sorry. I meant SYSEXFLUSH. Doh!
