Reply 180 of 452, by vetz
- l33t
wrote:OK I've tested SoftMPU on my ESS AudioDrive (ES1868F) as requested and it doesn't seem to work. I might be doing something wrong […]
OK I've tested SoftMPU on my ESS AudioDrive (ES1868F) as requested and it doesn't seem to work. I might be doing something wrong but it seems pretty straight forward, I type:
SoftMPU /SB:220 /IRQ:5 /MPU:330
And I get the error:
! Error: Sound Blaster not detected at port 220 IRQ 5
My MPU-401 however is detected at 330, according to the on screen message.
The Sound Blaster is detected at those settings by everything else, here's my SET BLASTER line:
BLASTER=A220 I5 D1 T4
This is on a PIII 1GHz machine booting directly to DOS 7
I can report the same problem on my ESS1888. The card have the ability to run with IRQ 2/9, so should be a good card to use SOFTMPU with when support is added in the next version 😀
