Reply 180 of 223, by Radical Vision
 - Oldbie
Suuuure this is why on my ABIT BE6-II all caps was ok, the board was 100% stable with 1GHz coppermine, im sure even Tualatin 1.4GHz will be ok on that board..
I have also many others boards that they did not have blown bad brand capacitors.....
So how the f**k then if many bad/trash/junk/garbage capacitor brands can  live so long, as they are all proven to be total trash, and you say the japan capacitors will fail how will that happen ?
They all have some life that will end in some time, all of them, just seems you forget the fact that the japan caps will last million times more then the trash china capacitors............................
From all the hardware i did have in my hands, i did see i did NEVER ever found blown rubicon, sanyo/nippon, panasonic capacitors so you can talk all you want..
It is your thing trow money on the fire with buying brand new expensive japan caps, meanwhile i will buy new Hitano and use japan caps from other hardware, and they will be more then fine, im sure they will not blow in MY lifetime (or at least most of them will not..)..........
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
