TNDLPT : Tandy Sound on parallel port
Reply 180 of 185, by Jo22
digger wrote on 2025-04-01, 08:26:
So how is a parallel port registered to be accessible on device name LPT4 in DR DOS and Novell DOS, if the BDA can't facilitate that?
Hi, that's what I've found so far..
"LPT4 is an optional built-in driver for a fourth line printer supported in some versions of DR-DOS since 7.02."
https://en.wikipedia.org/wiki/DOS#Reserved_device_names
"LPT4 (some versions of DR-DOS 7.02 and higher only[8])
Enables, defines count and logical order and configures I/O address and timeout for LPT4: device."
https://en.wikipedia.org/wiki/CONFIG.SYS#LPT4
"Further, it provided optional support for a LPT4: device and allowed to configure the built-in COMx: and LPTx: devices as well as to change the PRN: and AUX: defaults."
https://en.wikipedia.org/wiki/DR-DOS#After_Novell
Reply 181 of 185, by dreamblaster
New revision finally ready and available :
Limited Purple PCB 'Vogons Edition'
Thanks for your support !
Reply 182 of 185, by carlostex
Very nice! I plan to alter the AIL2 driver for Tandy, so it supports the TNDLPT directly (no need for TSR's).
And i have some even better news, but that on its own thread....
Reply 183 of 185, by dreamblaster
Now also the 3d printed case is ready
Reply 185 of 185, by ychh0
Recently I bought TNDLPT and I wonder there is any way to mute TNDLPT in Windows XP or higher.
I found TNDLPT output unwanted sound (noise) when booting until loading driver or running TNDRESET.EXE.
(When power-on there is no sound at first but it starts to output noise when starting to boot DOS until loading TSR or running TNDRESET.EXE)
For DOS, it has little problem. Noise can be stopped in very short time by loading driver or running TNDRESET.EXE in AUTOEXEC.BAT
But TNDRESET.EXE does not run in Windows XP or higher. I wonder if there is any way to reset TNDLPT in Windows XP or higher.
Thanks
