Reply 180 of 218, by Hirsch
RaiderOfLostVoodoo wrote on 2022-02-15, 16:48:
douglar wrote on 2022-02-15, 14:47:
So it looks like 600Mhz is out of reach at 2V.
Not at all!
Hirsch has one which can run 6x100MHz at 1.85V!
This is the result of the 9 CPUs I ordered for RaiderOfLostVoodoo and me. I didn't test with more than 2.0V (except one). When no 600 MHz is mentioned it doesn't run stable on 600 MHz@2.0V. I tested with Prime95 25.11 on a DFI K6XV3+/66.
Reply 181 of 218, by BitWrangler
Tried to give myself a small discount for buying 2 lots with an offer, but that timed out too... maybe too busy to check the offers or something. Actually tried to just BIN but Paypal is being a royal f*ckup again... keeps trying to force payment to credit card, I have the money in the bank, which is set as preferred, WTF is wrong with you. ( I gave PP a five year timeout for randomly deciding to ignore preferred or selected payment settings and denying they did it, hoping for something better to come along and/or hoping their lameass flaky code would get fixed if I waited long enough, even if it was by voodoo and cargo cult and pasting stuff from stack exchange or quora because they didn't have the first freaking clue.)
Reply 182 of 218, by Sphere478
You guys know, I’ve been trying to figure out how to turn these into k6-3+ cpus. But haven’t been able to find someone with a de lidded 2+ and 3+ to help me.
If one of you guys is willing to pop a lid off one of those and take some measurements between all possible combinations on the pads under the lid that would be awesome. Then I’ll only need a 3+ owner to chime in without a lid.
Sphere's PCB projects.
Reply 183 of 218, by pinesal
Not sure if this should be it's own thread. I received my CPUs today and I want to run it at 600mhz but I am having trouble understanding how to set the mobo jumpers. I have a FIC VA-503+
I think I have the bus frequency set to 100mhz and the voltage to 2.0 and the multiplier at 2x (interpreted as 6x by the cpu). But I get 556mhz.
Here are pics for reference and my settings. Can anyone see my error?
330.32 KiB
292.69 KiB
417.22 KiB
588.71 KiB
601.41 KiB
Hang out in the 90s with me on Twitch: The 90s Retro Gaming https://twitch.tv/90snick_pinesal
Retro Battlestation:
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
Reply 184 of 218, by Repo Man11
pinesal wrote on 2022-02-19, 22:09:
Not sure if this should be it's own thread. I received my CPUs today and I want to run it at 600mhz but I am having trouble unde […]
That's likely the fastest CPU speed that BIOS can display. When I first setup my Asus TXP4 with a K6-2+ @ 500, it displayed _MMX CPU @166 (or something very similar) - only after flashing it to the patched BIOS did it show both the correct speed and type for the CPU. Do you have the latest BIOS for that board?
Reply 185 of 218, by pinesal
Repo Man11 wrote on 2022-02-19, 22:46:
342.42 KiB
Yes, I think I have the bios version that supports the the k6-2+ and the k6-III
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
Reply 187 of 218, by pinesal
Repo Man11 wrote on 2022-02-19, 22:58:
What does it display when you set it for 6x95?
Hmmmm same, 556mhz. What is that telling us?
Here is a pic of the jumpers set for 95mhz. Am I doing this right?
346.36 KiB
Post 3 at this forum says it will show up as 556 but is actually running at 600mhz so maybe this is normal.
https://www.overclockers.com/forums/threads/k … 503-help.21753/
UPDATE!
Windows does report the cpu speed as 600mhz
Got a nice performance boost.
Before
283.87 KiB
After
285.54 KiB
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
Reply 188 of 218, by stamasd
Don't rely on what the BIOS says at POST, same motherboard same chip here, at both 95x6 and 100x6 it displays 556MHz but Everest sees the correct speeds (570 and 600 respectively). Also at 112x5.5, the BIOS says 622MHz, but Everest shows 615MHz (that's because the FSB is actually 111.9MHz, not 112).
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 189 of 218, by BitWrangler
I think it's only sometime in the last 15 years that CPUs even knew what exact model they were to tell the BIOS, before that, they only knew what architecture/series they were by CPUID and model was set somewhat mechanically by locked multi. So BIOS only supports CPUs by architecture really, and stepping level often, so at boot it plays "Guess what CPU this is" and the way to guess is look at CPUID and see which architecture, then run a teeny benchmark loop to see how fast it is, and then it guesses based on model speed quantization when that BIOS was released, or if it seems far enough off, just throws up a raw figure.
Reply 190 of 218, by Sphere478
guys, you're gonna love this... everyone needs to see this (256k cache enable mod)
Reply 191 of 218, by themajortechie
Sphere478 wrote on 2022-02-21, 05:14:
Mod the cache, crank the voltage to 2.1v for a stable 630MHz, and go crazy.
Reply 192 of 218, by Sphere478
themajortechie wrote on 2022-02-21, 06:00:
Tonk has the right idea!!
Now if only we could figure out what that other capacitor is supposed to be for? Smp? 😳 lmao!
It’s so awesome over 20 years later there is still stuff we can learn about this old hardware
Reply 193 of 218, by cyclone3d
Sphere478 wrote on 2022-02-21, 06:05:
Hah.. that would be something.
As far as anybody knows, the K6 and K6-2 and K6-III chips never worked in smp configurations on any publicly available motherboards though there is a rumor that there was an early dual socket 5 board that somebody got them working on.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 194 of 218, by Sphere478
cyclone3d wrote on 2022-02-21, 06:08:
yeah, I have a thread on that. I don't think that the capacitor is for smp. not much clue really what it may be.. maybe something to do with multipliers? not a clue.. maybe a 7x multi??
Reply 195 of 218, by TrashPanda
bloodem wrote on 2022-02-16, 11:31:
I guess that, as always, "playable" is in the eye of the beholder. :-D In this day and age, for me "playable" means somewhere ar […]
Sphere478 wrote on 2022-02-16, 08:44:
it's actually playable on k6-3+ 600 with radeon 9800 pro and this freeway mobo
I'm now attempting to set up the freeway ultra version of the mobo and a gf3 which I'm hoping will be faster
I guess that, as always, "playable" is in the eye of the beholder. 😁
In this day and age, for me "playable" means somewhere around 45 FPS average, with 1% lows that should stay above 25 - 30 FPS.
During my younger years, playable for me was 15 - 20 FPS AVG, and I would even tolerate dips below 10 FPS. Those were the days...
The Ezra T arrived today .. now to get the other parts I need to turn it into a working system.
Reply 196 of 218, by BitWrangler
So mine turned up now, sadly my socket 7 and super 7 stuff is inconveniently located at present, so can't play right away, will join in the fun later...
(Gah I give up on making the pics show up the the right way round, the phone was in more or less the same position for all of them, they're all "upright" when I scale them in Paint. )
    144.99 KiB
    Outer packing, real component distrib = real certificate of compliance, woooo!
    219.73 KiB
    Bubble mailer carefully opened with antistatic Bowie, sealed A/S bag inside.
    289.82 KiB
    Bundled up snug with extra card and antistatic foam.
    286.8 KiB
    The sixpack, all 2000 week 30.
Reply 197 of 218, by cyclone3d
BitWrangler wrote on 2022-03-01, 19:43:
Use GIMP or some other actual good graphics/photo editing app. That way the picture will actually be saved the way you rotated it.
MS Paint has been a joke for years.
YMF7x4 Guide
Reply 198 of 218, by BitWrangler
Gotta be a whole of windows thing though too, because they thumbnail and preview the right way up too.
Reply 199 of 218, by konc
BitWrangler wrote on 2022-03-01, 22:05:
You can rotate a photo by putting a tag on it (nothing really changes, just a tag to be displayed rotated), or by actually rotating it.
I have not identified what exactly has changed and this happens more and more often. My guess is that latest windows versions started tagging instead of rotating in more places, for example in the default image viewer. It's a good thing if you ask me in terms of original preservation and photo quality, but it's not communicated and we can see the implications.
edit: yep it looks like my empirical conclusion is a thing: https://www.howtogeek.com/254830/why-your-pho … rectly-rotated/
