Reply 1800 of 3431, by sharangad
robertmo3 wrote on 2024-06-23, 12:13:
the list of games that cannot be forced to render in very high resolutions on voodoo wrappers is here marked with red X: http:// […]
http://www.zeus-software.com/forum/viewtopic. … 72&p=3473#p3473
(excluding Battlecruiser 3000)
Starfighter 3000 might be excluded soon as the source was released recently Starfighter 3000 source
So just Whiplash and ef2000+ that 3dfx doesn't work with that rready does.
https://patreon.com/Rready
Reply 1801 of 3431, by RaVeN-05
look at 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D)
the Scorched Planet also had patch , and i must say original release have speedy3d support but its broken and not works on original hardware, you need to use patch.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 1802 of 3431, by sharangad
RaVeN-05 wrote on 2024-06-23, 13:02:
Ah ok! I'll look into that tomorrow. Thanks @Raven-05.
Reply 1803 of 3431, by Agent of the BSoD
sharangad wrote on 2024-06-19, 11:29:
Try this: https://nirvtek.com/downloads/Fifo.20240619.003.zip MD5: bf65722190f225450c6f7a512269c4d8 […]
Try this:
I went back to the most functional version of the app I had back on May 28 and tweaked a few things.
Tested it both in real mode and protected mode and got the same results. So, *fingers crossed* ... .
Tried this on my V1000, at the end it just shows some colored dots on screen and saves nothing to the txt file.
sharangad wrote on 2024-06-20, 23:30:
A test for Rendition owners with time to kill: […]
https://nirvtek.com/downloads/SpinningSquare. … 0240621.001.zip
MD5: 7f9192e7846a5a23e2fb4c9f1fb76993
See if it produces a rotating square or (most probably) garbage.
Garbage.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 1804 of 3431, by sharangad
Agent of the BSoD wrote on 2024-06-24, 01:39:
Tried this on my V1000, at the end it just shows some colored dots on screen and saves nothing to the txt file. […]
Try this:
Garbage.
Thanks @AgentoftheBSOD!. The speedy3d api code needs a lot more work.
Reply 1805 of 3431, by sharangad
Ok,
vQuake and Scorched Planet need the ucode to do specific things and report back by writing to the FIFO output queue.
I think I need to analyze the uc files before messing around more.
Reply 1806 of 3431, by sharangad
Ok, this should restore performance in ICR2 along with the Nascar fix:
https://nirvtek.com/downloads/RReady.Alpha.20240624.002.zip
MD5: 1fc3c0cd83edaaea73feb2e27cdc4a95
There'll be one more update to restore 32 bit register access for ICR2 and only for that tomorrow. Without 32 bit access ICR2 suffers momentary micro-freezes without threadsafe=true.
Everything else will use 8-bit access.
Reply 1808 of 3431, by sharangad
[EDIT]This is an untested build which restores 32 bit register access to everything except NASCAR2/1999:
I don't expect any nasties, but you never know. Tomorrow I'll test it and update this post.
[/EDIT]
[EDIT] This build works properly with all the currently supported DOS games.[/EDIT]
https://nirvtek.com/downloads/RReady.Alpha.20240624.003.zip
MD5: 670856fbe20bdb82d16a0aedab4fa58a
Reply 1809 of 3431, by sharangad
Do I need to make the internal config settings for games user configurable (in dosbox-rendition.conf)?
Turning Nascar 1999 to max graphical detail produces a chuggy framerate during a race. I could make the code I used to slow down the game, user toggleable for high detail modes Or add a per game config.
[EDIT] Nm. Random slowdown, probably a Dosbox /Windows scheduler priority issue.
[EDIT2] Here's Nascar 1999 with the graphics maxxed out. I've never seen it like this:
https://youtu.be/2PY-xnGV_68
Reply 1810 of 3431, by RaVeN-05
dosbox settings for each individual game , it very good idea, dosbox settings very varies depending on which game is used. if no exename.conf file found the default config will be copied to it.
Reply 1811 of 3431, by sharangad
RaVeN-05 wrote on 2024-06-25, 07:17:
I think that's probably the best way to do it. I'll add that to my to do list.
Reply 1812 of 3431, by sharangad
How stable are Rendition cards with faster CPUs?
Reply 1813 of 3431, by RaVeN-05
Well every game i played i used Pentium II slot at 350mhz , and all games are ok. Can't say anything about even faster CPU's , i think they will work as there video on YT by race sim central showing ICR2 under Windows 10 virtualization with true PCI access to real rendition card which is v2100 and it seems all works ok, as for other games completely unknown how they behave, only windows rredline games is exactly ok for me under rready, CPU AMD FX 8300 8core, 3ghz (don't remember correct amount CPU Hz)
at real retro machine i can use all games and i don't change anything, but real hw != dosbox, real hw ~ to 86box/pcem which LLE , and it works almost the same if not the same as real HW.
dosbox somtimes not provides all in one package to play everything without reconfiguring something.
dosbox is better by practical and usability meanings, unlike LLE where you need bios, install DOS or Windows OS inside , configure autoexec.cfg for sound or anything else.
dosbox is easy , just run game directly that's it.
dosbox is faster than LLE's.
Reply 1814 of 3431, by sharangad
RaVeN-05 wrote on 2024-06-25, 10:09:
Well every game i played i used Pentium II slot at 350mhz , and all games are ok. Can't say anything about even faster CPU's , i […]
Thanks @Raven-05. So my DMA problem is uniquely my own.
Reply 1815 of 3431, by sharangad
Does anyone have any documentation on Pentium DMA. This is all I could find:
https://edc.intel.com/content/www/xl/es/desig … a-controller_1/
[edit]
This looks like what Rendition uses;
Descriptor based Linked List
[EDIT] I tried using PIC based DMA access. It had a nasty habit of freezing with repeating audio.
Reply 1816 of 3431, by MadDogFargo
Interesting project! I had a couple Verite 2100 cards back in the day. At least I think that is what they were called. I should dig through my old boxes and see if I still have one...
Reply 1817 of 3431, by sharangad
MadDogFargo wrote on 2024-06-26, 07:47:
You should, they're great!
Reply 1818 of 3431, by RaVeN-05
And also by putting it to PC and make active, you can help this project by doing tests when asked by Sharangad )
Reply 1819 of 3431, by sharangad
RaVeN-05 wrote on 2024-06-26, 08:44:
Yes that would help!
