Reply 18420 of 59289, by bjwil1991
Bought an external 100MB ZIP drive with the software, and cables (extender, ZIP to PC Parallel cables, and power adapter) that I'm going to be using on my Packard Bell. Might get an internal IDE one for my K6-2 machine and a 10 pack of 100MB ZIP disks, and 350MB 2120XL data tapes on eBay.
Reply 18421 of 59289, by Jade Falcon
Rank BANNED
BANNED
Why not an IDE LS drive? holds more data and is more user friendly if you ask me. I guess LS disks aren't an every day find.
Reply 18422 of 59289, by SW-SSG
Got an external USB FDD, Samsung SFD-321U. Makes a cool "HMMMMM" noise when spinning. Neither of the two retro machines I've whittled down to have an internal FDD, so I bought this to use their BIOS' "USB-FDD" boot options for troubleshooting/etc. It works fine for that.
The attachment IMG_6894b.jpg is no longer available
Reply 18423 of 59289, by Cyrix200+
I have always been a bit afraid of ZIP drives since the click of death thing. Is there a way to recognise affected drives?
1982 to 2001
Reply 18424 of 59289, by cyclone3d
I've been very wary of Zip drives ever since I used them in college.
The dumb computers or maybe the drives themselves would randomly wipe all data from the disk without warning. If you didn't have a backup you were definitely hosed.
If you did have a backup, you better hope it was not on a zip drive as you had about a 50% chance that when you inserted that disk it would get wiped as well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 18425 of 59289, by cj_reha
ATi Radeon X1800XT 256MB PCIe
Boxed AOpen 802.11b PCMCIA WiFi adapter
PowerBook G4 w/o power adapter
DMS59 to VGA splitter
25 pin serial cable
a few cd games
Reply 18426 of 59289, by moawkwrd
A couple arrivals for my planned builds:
The attachment IMG_1078.JPG is no longer available
The attachment IMG_1076.JPG is no longer available
According to the label on the mouse, I may be a victim of piracy if it was supplied without a new PC. I should contact Logitech immediately!
Xeon E3-1241v3 - 16GB DDR3 - Vega 56 - W10
PII 450MHz - 256MB SDRAM - Voodoo 3 3000 PCI - W98SE
Reply 18427 of 59289, by torindkflt
For what it's worth I personally have never experienced the CoD or other catastrophic failure with any Zip drive I've ever used, which includes multiple internal drives in college and a mix of a few internal and external drives at home. Only problem I've had with a Zip drive is my USB-powered 250MB drive randomly "unmounting" the disk...not ejecting it, just suddenly acting like there is no disk inserted and refusing to let me read it until I eject and re-insert the disk (Spins down and starts blinking the LED slowly). Granted this could be a problem with 64-bit Windows and/or Windows 10, but it's never been a show-stopper since, like I said, all I need to do is eject then re-insert the disk to get it going again.
Reply 18428 of 59289, by TheAbandonwareGuy
moawkwrd wrote:
A couple arrivals for my planned builds: […]
XFX 8800GTS. Lifetime warranty. They still honor it. I put them to the test recently.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 18429 of 59289, by bjwil1991
The reasons why behind the click of death was because of the following:
1. Dusty cartridges or oxidized read/write heads
2. Power outage/unplugging constantly
3. Misaligned heads
4. Mis-written cartridges or damaged disks can damage the head
5. Missing pieces for cost reduction (like the 1995-2000 Chrysler/Plymouth/Dodge minivans with no Brake Shift Interlock)
Iomega had a lawsuit filed against them in 1998 and wasn't settled until 2001. The drives and disks later on were labeled which ones were/are bad later on in life.
Reply 18430 of 59289, by elod
Why get a potential brick?
Reply 18431 of 59289, by yawetaG
cyclone3d wrote:
I've been very wary of Zip drives ever since I used them in college. […]
USB ZIP drives 250 Mb can read the 100 Mb disks as well and usually don't suffer from the earlier drives' problems. Mine is now close to 15 years old and still works fine (except on my MacBook Pro, which seems to drive it very hard...).
Reply 18432 of 59289, by moawkwrd
It was cheap enough for it not to matter if it is.
Today's arrivals, slightly larger:
The attachment DSC00182.jpg is no longer available
Sharp 17" LCD with speakers, from 2002 roughly.
The attachment DSC00181.jpg is no longer available
Two of the beige towers are for harvesting parts and then selling on what I can't use. Will be using the Gateway tower with it's lovely stickers for my Windows 98 machine. Black Antec Tower is for Windows XP.
The attachment DSC00183.jpg is no longer available
Wyse rubber dome PS/2 keyboard, looks to be from the early 2000s judging by the Windows keys. As new in box.
Reply 18433 of 59289, by Cyrix200+
I put a relatively low starting bid on this item, to my suprise it was immediately accepted by the seller. Quite happy with it. Paid 60 euro for it.
1982 to 2001
Reply 18434 of 59289, by luckybob
@moawkwrd
love that antec case in the middle. I had a black one and crammed a P4 inside it. I would not mind getting another.
Reply 18435 of 59289, by Cyrix200+
moawkwrd wrote:
<snip> […]
<snip>
<snip>
<snip>
Love the beige cases, the Antec is a true modern classic!
1982 to 2001
Reply 18436 of 59289, by elod
luckybob wrote:
@moawkwrd
I still use mine daily but I have to admit that the NSK4000 on the right is better.
Reply 18437 of 59289, by boxpressed
This arrived today. I'm a sucker for all Ti4600 cards. The Nvidia 45.23 Control Panel identifies it as a Ti4800, however!
The card is almost new, and the cables are still sealed. New manual. $28 shipped from shopgoodwill.com.
UPDATE: I just learned that the Ti4800 is an 8x AGP Ti4600.
The attachment IMG_0506.JPG is no longer available
Reply 18438 of 59289, by agent_x007
Athlon XP has nothing on my "new" PSU =)
The attachment Tagan TG420-U01.jpg is no longer available
Reply 18439 of 59289, by Tetrium
If that PSU is anything like my 370W Tagan, it will be very tightly packed and not have a lot of airflow. It's ...somewhere in the middle perhaps when it comes to build quality (partially due to the parts chosen, like certain caps)..but mine is very heavy!
Will be hard to repair due to how packed that PSU is. I got one due to the good 5v and 12v rails back when my Barton 3200+ was still the fastest thing I could lay my hands on.
My Tagan did work reliably, even though I didn't fully trust it (yes I ended up having basically zero problems with mine).
I'd personally prefer the middle one though. But I also like the Gateway case to the left (but I think the center beige one looks best). The black case seems like a run-of-the-mill black/silvery case though.
My retro rigs (old topic)
Report spammers here!
