Reply 19380 of 58608, by Cyrix200+
Tetrium wrote:
Cyrix200+ wrote:
A Reborn card, might be fun to play with if I can get the software somewhere:
<snip>
I might actually have the software. I got like 10 or so of those cards as hand-me-downs? I may even have the paper manual 🤣!
Will probably don't have time to go look until this weekend at the earliest.
No hurry, It's not high on my list of things to do:)
1982 to 2001
Reply 19381 of 58608, by bjwil1991
Cyrix200+ wrote:
Tetrium wrote:
<snip>
I did research on the card and it looks like a recovery PCI card in case an OS had a nasty virus that destroyed the OS, it'll get the OS up and running again, boot up to 40 partitions at once, and HDD cloning as well.
Reborn-PCI Systems & Data Recovery Card
I might get my hands on a few of them for my machines running 98SE and XP, and there's a version for Windows 7-10 called Lenten Reborn Card for the PCI-Ex systems (either UEFI or Legacy BIOS).
Reply 19382 of 58608, by andrewreader
I've finally got a 486 in my collection.
It was an Ebay auction win.
A Sound Blaster 16 Value ISA card
A Vesa Local Bus S3 Video Card
A peripheral card (parallel and serial)
A network card (ethernet and some other serial connector)
A CDROM Drive (not sure of speed) - working
A HDD (not sure of size) - working
It also came with a Vision Master Pro 450 monitor. This weighs a ton.
And there was some barrel battery leakage.
The packaging was awful. A reusable carrier bag and bit of bubble wrap.
I've taken the battery off. I'm looking to install a coin battery slot.
The case is a little bit scrappy in places, but it has got a working LCD, reset and turbo buttons.
Reply 19383 of 58608, by ElectroMan
Reply 19384 of 58608, by lazibayer
Cyrix200+ wrote:
ATi based, need to check chipset: http://i.imgur.com/Z73NvCPl.jpg?1 […]
Z73NvCPl.jpg?1
It's Mach64 VT4 AKA Video Xpression+. Interestingly it has Rage2C marked on the firmware chip.
Reply 19385 of 58608, by liqmat
Ozzuneoj wrote:
Awesome find! I have a CT1350B myself. The empty sockets are for the CMS (Creative Music System) upgrade. The specific revision of your card and the DSP chip determine whether or not you can actually do the upgrade without side effects. Some late 80s and early 90s games used CMS music as a more advanced alternative to Adlib\FM (Yamaha OPl2 or OPL3) music. Here's a whole thread about the upgrade:
SB 2.0 CT1350 CMS chips dumped
Two of the chips are fairly easy to find on eBay. The other chip must be programmed by someone... which, thankfully, is possible now due to the diligent efforts of communities like this. 😀
Good grief Charlie Brown! Someone wants a lot for that upgrade! Not for me and I certainly don't have a programmer. Unless you guys know a cheaper way to go about it?
http://www.ebay.com/itm/Creative-CT1350B-CM-S … GEAAOSwyc1ZnlwV
Reply 19387 of 58608, by cyclone3d
badmojo wrote:
That's a nice find, I have that one and really like that GM chipset. It should look like this I suspect: […]
cyclone3d wrote:
Also have an IBM Aptiva sound card S-16WP1/L with the original wavetable daughtercard. From the research I did before buying it, it looks to basically be an Acer Magic S23A in functionality minus IDE except for the wavetable part is a daughtercard instead of built onto the board.
Card just came today. That is indeed the same exact daughter board as the one I received.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 19388 of 58608, by brostenen
Bought this today for 20 Euro.... Sellers picture.
Never had any caching controller, and never had any ISA with BIOS on it.
Really looking forward to play with this card when it arives. 😜
The attachment caching-isa-controller.jpg is no longer available
Reply 19389 of 58608, by Ozzuneoj
Wow, that's pretty pricey!
I'd recommend posting in that thread with the revision number of your card and the version number listed on the big DSP chip (CT1336A for example) to determine if your card is compatible with the upgrade. If it is, there are people around who can program a chip for you for a lot less than $50. Then you'll just need the pair of Philips SAA1099P chips Deksor posted.
Reply 19390 of 58608, by liqmat
Will do. Thanks. Now I just need to find a reasonable 8-bit VGA card so I can get an ITT Xtra XP system up and running.
Reply 19391 of 58608, by Deksor
Somebody here programmed a chip for me. That chip + the two cms costed me less than 10€ including shipping, go check miliways for the thread about the upgrade chip
Reply 19392 of 58608, by liqmat
Unfortunately I do have the bastard 1336A chip so not going to happen. Thanks for all the help.
Reply 19393 of 58608, by luckybob
wish i had one for ya. 🙁
Reply 19394 of 58608, by gdjacobs
Pabloz wrote:
Deksor wrote:
Pabloz wrote:
https://s1.postimg.org/4tyys1ou7j/yamaha.jpg […]
yamaha YMF 724F-V
and somewhere
on the deep web....the drivers i will find
The drivers are on yamaha's website
i saw someone posted the link on vogons but the link got removed,like if yamaha changed its website
Yamaha reorganized and they no longer have links to the archive, but the files are still there.
http://device.yamaha.com/en/lsi/download/
Reply 19396 of 58608, by badmojo
What do you think of the sound if it? I really like it, particularly for games like DOOM, Duke3D, etc.
Reply 19397 of 58608, by cyclone3d
Haven't tried it yet. Busy building a couple machines.
YMF7x4 Guide
Reply 19398 of 58608, by shiva2004
Cyrix200+ wrote:
This bunch got delivered a few days ago. Not very special but it wasn't very expensive (just a few euro). […]
My apologies for the bad pictures, I dropped my phone a few times too many it seems...
Two Avance Logic ALG2302 based video cards. I didn't have one of these before:
ya2smXDl.jpg?1
CSEm2Xkl.jpg?1
You didn't loose anything special, believe me, I suffered one of this crap cards for a too long time 😢.
Reply 19399 of 58608, by Gamecollector
liqmat wrote:
ATX MBs w/o the 3rd row of mounting holes. HATE!!!
