Reply 19420 of 30158, by Merovign
That Boiler PC is pretty Fallout.
I'm making really slow progress toward documenting my collection, but it is progress. I'll get pictures of the new shelves later (my new Mobo is arriving Tuesday, and my backup XPS 8700 has flaky USB, which is not uncommon with Dells of that era).
I will get everything "old" documented before integrating the last Liqmat Haul, which is still boxed (just not in the shipped boxes), so I still have the option of doing an "unboxing" video, which will be easier with more space cleared.
The 3D Printed brackets and posterboard for shelves worked really well. I got the amount of plastic in the brackets down about 40% from the first attempt, which speeds up printing time (and extends my supply). I designed a cutter for the posterboard to speed that up, too.
The various cards fit well on the shelves, each section has one row for larger, more modern video cards, and the CPU trays I designed fit in the slots along with video, sound, controller, and other cards. I have a project started to design holders for RAM that fit in the slots, but I won't print anything for that until I've checked to see if there's anything I can buy cheap that will do just as well. I can easily design shelf sections with other sizes, the current set were designed just for expansion cards.
I need to clear enough space to move my 3D printer across the room, I *might* get that done today or not, and I need to set up a better "disposal" box for truly broken stuff as I continue sorting.
*Too* *many* *things*!
