Weird cards found inside Dell Dimension M233a
Reply 20 of 23, by PC Hoarder Patrol
nfraser01 wrote on 2024-04-21, 12:23:
Agreed - the ET4000 cards disbale the onbaord video in my machine also. […]
Robx66 wrote on 2024-04-21, 07:45:
Those CL cards are working.... sort of 😀 Anytime when one of these are in isa slot then signal from integrated vga is disappearing. When pull it out then integrated vga gives signal again. Seems like that cards are overriding signal or disabling integrated vga card. Would be great having cable either DC37 or that 40 pin one or maybe even taking output from vesa 26 pin slot.
Unfortunately I haven't got any.
I'm luckier in that they just have standrad VGA connectors and have confirmed they work (as far a displaying POST/BIOS)
I'm hoping to find some Windows 3.1 drivers for them...
Here's a better laid out spec page for the system (with options) - https://web.archive.org/web/19971008001613/ht … mmx/indepth.htm
Apparently there were two versions of the system board...the cache-memory card socket (COASt) was populated only on early versions of the Dell Dimension P133a, P166a, M166a, and M200a systems. On later versions, the cache memory chips were soldered directly on the system board.
The basic system board is actually already on The Retro Web, if someone wants to submit some clear photos for inclusion (seems to list the wrong video chip though). A02 BIOS is also available there - https://theretroweb.com/motherboards/s/intel- … x-hannibal-plus
Was right about there not being many files listed for the system, but here's a list of the available download links - https://web.archive.org/web/19970605172909/ht … ilelib/194a.htm
The attached file claims Win 3.x driver support for the Virge/DX, but you might also try Vogons Drivers here - http://vogonsdrivers.com/getfile.php?fileid=1713&menustate=0
Also came across a similar card which too seems intended for muli-card / multi-monitor support - https://www.reddit.com/r/vintagecomputing/com … video/#lightbox
w3110505.zip
Reply 21 of 23, by Robx66
weedeewee wrote on 2024-04-21, 13:07:
finding the pinout for the twin GD5428 card seems to be as simple as reading the datasheet for it and doing a multimeter continu […]
finding the pinout for the twin GD5428 card seems to be as simple as reading the datasheet for it and doing a multimeter continuity measurement.
If the signals are capacitively coupled you 'll need to do it in two or more parts.
page 42 , 3-10 , https://datasheetspdf.com/pdf-down/C/L/-/CL-G … CirrusLogic.pdf
edit:
77: red
76: green
75: blue
69: HSYNC
68: VSYNC
Table 1-4 page 48 , 3-16
This is great !! Thank you !
Save vintage / retro computers from ending up in the bin. Keep them in working condition. It's a great history !
Reply 22 of 23, by Robx66
PC Hoarder Patrol wrote on 2024-04-21, 14:12:
Here's a better laid out spec page for the system (with options) - https://web.archive.org/web/19971008001613/ht … mmx/indepth.h […]
w3110505.zip
That's a good find 😀
Thank you !
Reply 23 of 23, by Robx66
Found that CL card on ebay and some German site. According to that it is ASTRA ACM-602.
So far can't find any specific drivers for it 😒
