I'm a radiographer… for which you need a specific degree, for which I signed up after quitting computer engineering (partially because yes, don't turn your hobby into a job, mainly because too many maths which I totally suck at, partially because it was too early to see your ex daily)
Well, I'm also unofficially the first level tech support there 😀
darry wrote on 2024-04-20, 01:13:
used punched cards in a professional context, whether while working in IT or otherwise ?
First real job, where we had a Max ER-1500 time clock, yup probably a 90s design…
And playing with the definition of "card", our local swimming pool got these green sticks as a substitute for coins for hair dryers: https://www.romanoattrezzature.it/asciugacape … li-per-piscine/
Errius wrote on 2024-04-22, 08:03:
AS/400 is surely still a thing under false name? 😀
But the newest-designed product must be a circa 2016 adapter to use an InfoWindow II terminal on a modern PC!
