Replacement for Chaintech 5AGM2 bracket?
Reply 20 of 30, by Demolition-Man
As the person in the world who is the worst at soldering, I would say let's just try my luck with some connectors.^^
Reply 22 of 30, by Repo Man11
I happened to be working on a CDROM today that had the same sort of connector that I salvaged (actually a pair of them) from a dead CDROM to use with the USB backplate years ago. The spacing and size are correct, but I had to trim and file down the plastic to make a pair of them fit on the pins.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 23 of 30, by Demolition-Man
Thanks.
There are suitable 2.0mm USB brackets. One less problem. The PS/2 mouse connection remains. The pins for this are not on a line and must be connected individually. There are 2.0mm to 2.54mm jumper cables, but only two-pin. Three of those and it should work. Not pretty but doable.
Reply 24 of 30, by Demolition-Man
So, 2mm 2-port USB bracket arrived.
Bad picture quality as always, sorry.
I`m ordering a bunch of Jumper cables (2,54mm & 2mm) für the PS/2 connection right now.
Reply 25 of 30, by Repo Man11
Demolition-Man wrote on 2024-05-19, 13:01:
That looks very nice, I wonder how many other motherboards use this size pin spacing? This Chaintech board is the only one I've seen. I'm reminded of the joke "That's the wonderful thing about standards - there are so many of them!"
Reply 26 of 30, by Demolition-Man
I have no idea where else you could use the 2mm version, there are plenty of them.
Reply 27 of 30, by PcBytes
That 2mm header looks pretty familiar to me. I remember the Original XBOX controller ports using the same header.
Reply 28 of 30, by Demolition-Man
It`s also a variant of CD Audio plug, as already mentioned.
Wouldn't be of any use on the PS/2, 4 pins in different places.
At least here there are no individual 2mm jumper cables, always only as 2pin.
It's a bit of a mess, but I'm confident it will work.
Reply 29 of 30, by weedeewee
I see the adafruit ones have, as said, two pins.
one could easily remove the pins from the plastic two pin holder and add some heatshrink sleeving or a wrap of insulating tape to each pin separately.
Do not ask Why !
Reply 30 of 30, by Demolition-Man
The 70 cent non-soldering solution. I removed the excess second cable from two plugs.
Not perfect, but usable, I think.
I have no idea when I'll be able to test the motherboard, but I've got all the accessories together now.
