Reply 20 of 27, by GeorgeMan
Just a quick update.
Windows 95 cannot work with hercules graphics at all.
But it does work with EGA graphics, which is converted on hardware level to digital (TTL) out by the ATI VGA Wonder+ card.
I read a couple of references that it's "painful", but honestly it's workable and definitely not more painful than the original 640 (or 720) by 350px HGC mode on Windows 3.1 etc.
Of course it's immediately obvious that most of the software is not designed to be used in such low vertical resolution and there is MUCH software that you cannot even install without a VGA compatible display. For this software, all you need is to switch to standard VGA driver and power on the computer with an analogue monitor connected to the ATI card (it's compatible with both and auto configures itself on power on), install the "VGA" software and then revert to TTL/EGA and try running it. Most of the time it works, except of course for most of the VGA-requiring games.
Honestly the VGA Wonder works wonders, it's like magic that no configuration is needed. Just plug the needed type of monitor before powering up the machine.
I ended up combining it with a Pentium-200 based system so I can finally listen to my winAMP mp3 playlists on Windows 95 on the amber 12" monitor. 😀
I completely forgot to take any pictures, but I shall take and update this thread a couple of weeks later.
Now I need to figure out a way to make Windows 98 work with the ATi VGA Wonder+ with 640x480@256colors on the VGA analogue output. Default driver allows me only 16 colors and choosing 256 colors is only available on resolution 800x600.
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 21 of 27, by doshea
I checked a Microsoft TechNet CD from 1997 and couldn't find anything saying whether Hercules should work with Windows 95. I expected to maybe find something saying it's not supported, but didn't.
Reply 22 of 27, by Grzyb
doshea wrote on 2024-09-21, 12:54:
It's clearly stated on the box that VGA is required:
The attachment w95box.jpg is no longer available
It's impossible to install from scratch without VGA - the installation program runs in a VGA mode 12h.
Nevertheless, Windows 9x can use some drivers made for Windows 3.x, eg. the EGA driver.
I saw some report about using it with Hercules as well, but I don't know any details...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 23 of 27, by GeorgeMan
I can confirm that the installation run fine while upgrading from windows 3.1 using the already installed EGA driver.
But it didn't work if using Hercules driver. And I've not seen any proof that someone managed to get 9x working with Hercules graphics.
Also, it's amazing how slowly the GUI is drawn with EGA on the ATi VGA Wonder+, even combined with a Pentium 233 CPU. 😀
I've also uploaded a video, you can watch it here. Enjoy!
https://drive.google.com/file/d/1HsASwnWbjPKL … ew?usp=drivesdk
It's amazing how it can produce some shades of amber on a digital monitor.
Reply 24 of 27, by BitWrangler
I might have seen Win95 on a Hercules mono standard monitor one time, I might have not. Twice in the 90s I went to use an ATM (Cash Machine) and found it crashed, one time, around 1995 or so, it was hung on the Windows 3.x loading screen, and it was sharp and correctly positioned, don't think it had shades, looked much like when I ran 3.1 on mono monitor in hercules mode... then a few years later, maybe 99, I again found an ATM crashed... the ATM hardware looked very similar to the first one, and the customer interface had not changed much, so it could all have been the same hardware, apart from CPU/Motherboard upgrades, or it may not have been. However in that instance it was crashed to a Win95 desktop but it was at least 4x normal size, like the start button took a 1 inch by 2 inch block of the screen approx, and was distorted and you could see scan and flyback lines. Just the sort of thing you would expect when some 31khz or higher signal is trying to go into a 15-18khz capable tube.
Now, I don't know if a driver had disappeared or corrupted and Win95 was meant to be showing through like that, the normal ATM customer interface did not look very graphical, it looked very text mode terminal-ish. So I am not sure if the way they did it needed a windows driver to be operating the customer interface, or whether it fullscreened a terminal or DOS session. Anyway, I would go digging in the Point of Sale and ATM type portions of the internet to see if there might be anything useful.
But anyway, I might get to doing some of this type of stuff myself in mono and color, have a mono monitor, considering grabbing a semi-local EGA monitor and seeing what the ATI EGA Wonder, VGA Wonder, VGA 16 and a fancy seeming Video 7 TTL card will do.
edit: btw the slowness of the GUI on EGA, that's with zero, nada, zip 2D acceleration features. It's actually kinda hard to find anything but very early or very cheap VGA implementations without ANY kind of 2D acceleration of some kind, not the more sophisticated blitting stuff, but just basic drawing boxes, which helps more than you'd think. So if you find a very barebones VGA implementation, you may find it comparably slow.
Reply 25 of 27, by FalconFour
Thread glue: Our wishes are now fulfilled. Witness: Herc9x - a Windows 95/98(/ME?) display driver for Hercules 8-bit ISA cards now exists
The attachment IMG_6232.JPG is no longer available
Windows 98 on Hercules.
It's a bit of a broken and unstable mess, but I sanded off a lot of the rough edges along the way. It's quite usable (been playing Winamp for about 2 hours now - on an IBM MDA screen), but has... some issues. It's great for absurdity but may not be ready for VCF expos yet (due to system-hang crashes). Hopefully it can be polished up before next VCF West. Plenty of time...
Reply 26 of 27, by GeorgeMan
Amazing! I shall thoroughly read your thread! You know, I explicitly bought the ATi VGA Wonder+ for the exact reason that it can convert EGA to drive monochrome TTL monitors in hardware. It can even fake some kind of "shades".
For me the the most annoying part of that process is the (lack of) vertical real estate. 350pixels of height just doesn't cut it for any windows experience.
Your desktop seems to amazingly have more vertical real estate available!
FalconFour wrote on 2026-02-17, 06:11:
Thread glue: Our wishes are now fulfilled. Witness: Herc9x - a Windows 95/98(/ME?) display driver for Hercules 8-bit ISA cards n […]
Reply 27 of 27, by rmay635703
GeorgeMan wrote on 2026-02-19, 07:54:
Amazing! I shall thoroughly read your thread! You know, I explicitly bought the ATi VGA Wonder+ for the exact reason that it can […]
For me the the most annoying part of that process is the (lack of) vertical real estate. 350pixels of height just don't cut it for any windows experience.
Scaling and font selection do wonders.
He uses a virtual screen of a higher resolution first which is scaled to the 720x350 resolution.
Using CGA under Windows 3.1 was possible but unless you used the correct fonts nothing fit on the screen
