Reply 20 of 21, by wbahnassi
- Oldbie
Matchstick wrote on 2024-06-28, 23:38:I think the OP found the one instance where this was a fluke.
Yeah that was the first time I see such approach in production.
Errius wrote on 2024-06-28, 22:54:I'm thinking about getting into 3D printing just because of this.
I also had to 3D print parts.. luckily those are for interal uses (drive rails), otherwise I would have loved if this paint thing was figured out as I could then spray paint the printed piece and color-match it with the rest of the computer case.
I have a Cambridge Soundworks 2.1 speaker set that have yellowed (or rather, oranged) badly on certain sides... maybe they're good for an experiment...
cdoublejj wrote on 2024-06-28, 06:37:i've always wondered about that but, the paints i see usually rubb off, maybe it was a two part paint with hardener...for plastic.
Regarding paint rubbing off, there are also protective coats to prevent that.. But I tried a black satin-finish primer+paint spray combo can, and it ended up quite solid. Just keep in mind:
- Don't spray in an open area where there is air movement. Dust particles will immediatelly stick and sink into the fresh paint.
- Don't focus the spray for too long. Otherwise you will get droplets that slide down and clump at the bottom edges.
- Don't listen to the drying time claimed on the can. Mine said 2 hours, but it took 2 days to become fully dry and non-sticky.
I've seen shops color-match paints for regular paints, not spray can paints. Is there a technique to apply those liquid paints evenly on complex objects?
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
