Reply 20 of 24, by Cursed Derp
- Oldbie
I got a lot of good friends in windows
I am as smooth as a gravy train with flaming biscuit wheels.
Okay windows still works
Windows works fine now
Here's my latest configs. I've tried to upload these a few times but they weren't posting for some reason
If not booting to Windows but are booting using the option EMC, try to load high in your autoexec.bat file the two TSRs loaded from the C:\DOSDEV directory. 😀 Also, it appears that, while you are using QEMM, you didn't use OPTIMIZE. I can tell, because I see that you are using LH or DEVICEHIGH to load high some programs, and you are not specifying in which memory area to put the programs. It will take a lot of work, but it can help if you optimize your config yourself. Just use MEM/D/C to view the current memory config then experiment by moving things around in memory and seeing what happens. For example, if one program seems to fit better in a different location, try putting it there and see what happens. To move a program to a different location, simply use "/L:x" either between DEVICEHIGH and = or just after LH. When you're finished, tell me what happened and provide your memory report. 😀
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
