Reply 20 of 30, by douglar
- l33t
Tempest wrote on 2024-07-09, 19:34:Dumb question but on my Pentium 1 I'm using Windows 98 SE (my 486 is for pure DOS games). What's the largest CF card that I can use with it? I know Windows 98 can recognize larger hard drives than DOS 6.22 could. I assume that for Pentium 1 era games that DOS 7 is just fine.
Also that StarTech CF adapter looks like it has a rear mount that goes in a card slot. Since I don't have any bays free on the front of my machines this would be ideal. Has anyone tried to do this before?
Many people prefer the rear slot. Don't read into that much. We are all talking about computers here. What is your preferred way to mount a CF in a DOS / Win build?
I typed up some info about the BIOS limitations here: https://www.vogonswiki.com/index.php/Storage# … age_Limitations
There's no physical reason you cannot get a very large CF. All the pins are there. If you get an LBA48 BIOS and have money to burn, you can go over 128GB but you might find that a slower pentium has a little lag calculating the free disk space though.
The common SD sintechi SD bridges on the other hand have a hard stop at 128GB. They only support LBA28, not LBA48.
