Dell Latitude XPi CD Laptop DOS 6.22 / Win 3.11
Reply 20 of 24, by MAZter
jtchip wrote on 2024-07-24, 22:39:
The audio is on a separate daughterboard so that can be replaced on its own
That's good news, in this case I recommend take it out from the slot and put it back. Sometimes contacts could shift over time, I repaired 3-4 laptops this way.
Doom is what you want (c) MAZter
Reply 21 of 24, by wierd_w
careful application of deoxit might also be fruitful.
Reply 22 of 24, by magestic
i found another of the same laptop cheap on ebay, going to see if i could swap sound devices....
one apart, i'll clean with deoxit
Reply 23 of 24, by magestic
So i ended up with 4 of these models for whatever reason, on a whim, i loaded up windows ME on the one the sound didn't work in dos, and low and behold i got working sound! Baffled why DOS is a no go.....
Reply 24 of 24, by Dodobird
magestic wrote on 2024-08-23, 00:49:
I had no sound in DOS too, and ended up buying 2 more units for part swapping but in vain. I almost gave up until I realized it requires a very specific driver.
It's a great machine tho, here's a review:
https://www.youtube.com/watch?v=GGMdhc9x2ww
Download Dell XPI CDdriver:
download/file.php?id=181958
Run the ESSCFG file and it should list the resources it uses.
The IRQ is hardwired to 5 on mine and I would guess it might be the case for yours as well. So, don't try any other IRQ, it will mess it up and you will have to reboot, otherwise it will look like it's not working.
You can change the other resources (again do not touch the IRQ).
Then you only need to set the Blaster environment variables: e.g: SET BLASTER=A220 I5 D1 T4 P330. I hope this helps.
