Trashbytes wrote on 2024-08-20, 05:48:
r00tb33r wrote on 2024-08-14, 05:47:Test results:
NFS HS replay loop: 42°C hottest point
Prime95 stress test: 40°C hottest point […]
Test results:
IMO acceptable numbers. Exactly how the game is hotter than Prime95 I have no idea, but that's what it is.
I'll be making fan mounts for my Voodoo 3 cards next. By the way, if anyone has a community project that needs printable parts designed I'm up for it. I enjoy this more than playing games anyway.
You may need to make a two fan version of the cover and then hook the fans up to a speed controller and lower their RPMs...two fans at a lower speed should in theory cool better than one fan at a noisy speed. I have a PIII with an after-market cooler with dual fans and a chunkier heat sink, its a far better setup than the tiny cooler Intel used.
A printable dual fan shroud would be a nice option to have along side the single one.
Actually, I think it will be acceptable, because it is not really louder than hard drive motors. So for this reason I think "it will do".
As for multiple fans, it will be a fairly drastic difference because the fans would have to clear the push pins that hold the Intel cooler together (they go through the heatsink and processor card to clip into the plastic backplate). Sure, there's no actual reason for them to be that long, they can be trimmed to be shorter, but I generally prefer non-destructive modifications. I liked this design I produced because it just clips onto the factory stuff without damaging anything.
As-is, the 40mm round cutouts for the fan airflow will interfere with the Intel cooler assembly pins... It's possible to design raised pedestals to clear the pins as they are, I just don't love how that's going to come out. But if you want this, I can certainly make you the file, that's not a problem at all.
The attachment p3 dual shroud.png is no longer available
I will note here that the Noctua fan does come with "noise reduction" adapter cables, they have resistors in them. I think a lot of Noctua fans come with those. Then all you'd need is a Y-splitter... But like I said, I think the single will do if the system has hard drives.
