Reply 20 of 479, by igna78
stamasd wrote on 2024-09-02, 21:41:He said the USB connector would be used by addon cards plugged alongside this one in the connectors above the ISA fingers. Or possibly in the smaller connector located behind the USB port. Or both. 😀
I had read, but I don't understand why an add-on should be powered via an external USB connector: would I then have an external cable that would then have to go back inside? .. it seems impractical to me.
And then if there is the possibility, from what I see from the prototype, to connect a possible add-on directly to the
ISA lines (which can also provide power), what is the advantage of the USB connector? 🤔
Understand me, mine is curiosity / desire to understand 😀
The fact remains that the project is fantastic (I have always hoped for a quality ESS card produced by Team Orpheus) and that I will already on the list to have this card too 😁
