Reply 20 of 32, by MechWarriorZero
- Newbie
I tried installing Windows 95 but didn't work?
Huh?
The OS the raw hardware is running is win95.
Yes?
and for some reason the windows version of mw2 won't install.
Yes?
I built:
it just didn't work installing Windows 95 on it
Are you attempting to install w95 on Dosbox or the actual hardware?
I built:
Windows 95 on my IBM Aptiva
Right.
So it's actual old hardware.
Running actual windows95.
And when you run setup.exe or install.exe on the mw2 cd what happens?
BTW you have ZERO reason to run dosbox.
You HAVE actual DOS.
I built:
as I just said I can't install Windows 95 on my IBM Aptiva, the CD image that I downloaded has a corruptive command.com file
so what IS it running?
ffs I've asked you 4 times already
I built:
its running 98, but would like to install 95 on a separate hard drive
Ok great.
You have 98.
Mw2 will run fine on 98. There's no need for 95 or dosbox.
Just run the installer on the Mw2 CD.
I built:
I know that but would like to also run 95 too
The original title of this thread was "make dosbox easier" and your stated goal was to run mechwarrior 2.
Do you even know what the hell you want?
I built:
I'm done posting 🙁
