Reply 20 of 29, by stealthjoe
Horun wrote on 2024-12-30, 06:09:An eeprom programmer is one of the most valuable tools anyone doing vintage can have and pays for itself with just one use. With it you could check your prom and see if it is still good, and if is can flash it.
Till date, was not having the need for a programmer but I am now contemplating on getting one. Cost seems to be a little prohibitive though for the 40 pin ones.
One note about making a bootblock flash recovery disk: Never test it on a working computer because if you did it proper it will/could write to it's eeprom messing it up.The proper command line structure for a boot black flash forces a bios write....
Agree on this. That is one reason I first tried it on a VM and on DOSBOX as well 😁 and any how it failed to start specifying BIOS mismatch. Same case with my actual PC. However, need to careful nevertheless.
soggi wrote on 2024-12-30, 07:02:Depending of were you are situated you can also ask VOGONS' users to do that for you for a couple of bucks.
I am from India and yet to come across anyone into retrocomputing in my vicinity. So this seems like a dead end.
soggi wrote on 2024-12-30, 07:02:Yeah...like Horun said, a programmer is very valuable - especially if you don't have another board to hotflash (for that it mostly only needs support for the same type of EEPROM/Flash, the rest doesn't matter normally). Because I own a wide range of boards, I don't have a programmer until now...but have to buy some one in the future, it's easier to handle and there's lower risk.
If I understand for hotflashing, only the actual ICs need to be matched and doesn't matter if it is from a totally different board/socket type. Let me know otherwise. If so, I do have an Asus P2B rev 1.10 and need to find it. Meanwhile if somebody could chime in on the IC model on the same P2B rev, would be helpful. The current IC on the M6VLR is Winbond W49F002U-12B.
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
