Reply 20 of 28, by Trashbytes
- Oldbie
rolierop wrote on 2025-05-26, 15:45:I cleaned the slot again thoroughly, reseated the CPU a bunch of times. The post-analyzer card gets pased C0 and C1, so memory i […]
The post-analyzer card gets pased C0 and C1, so memory is seen. If I remove the memory it hangs on code C1. But after C1 the next code is 00 and it stays at that.
So to me it seems the processor is working or else the post analyzer card could not do anything. Processor also gets warm.
Code 00 does not seem to mean anything??
Hmm have you also cleaned the ram slots the same way ? give that a shot and while you are there inspect each slot to see if there are any bad pins.
