Reply 20 of 23, by tony359
- Member
Thanks, I had the latest SW already.
I can indeed do that test for you. Watch this space!
Thanks
My Youtube channel: https://www.youtube.com/@tony359
Thanks
I've had a couple of SSDs fail, but none of them died because of a lack of trim.
Thanks @Sleaka_J - I've decided to go with an old fashioned (brand new) mechanical drive, just to rule out any possible issues. For my personal use, I'd go with an SSD for sure 🙂
@Nehalem501
Here it is: https://1drv.ms/u/c/0f215fbb023f1ee9/EXvBFyUI … Y-R6Sw?e=HgVhMf
I was looking at the logs while copying (on a monitor), I see the XD10 copies everything in a temp folder and then renames everything. If those logs could be useful, I can try and fish them from the drive.
I've also included the RWM folder in case you needed it.
Let me know if you can see the files.
Thanks!
Thanks for the file. It seems like everything I need is there.
I will keep you posted with my progress.
