Reply 20 of 27, by SScorpio
Linoleum wrote on 2025-08-17, 13:54:
I followed your recommendations and picked up a GTX 750 Ti—found a few locally for just $20 CAD. I’d forgotten what a gem that card is! It packs an impressive punch for its size and needs so little power. I also scored a Sound Blaster X-Fi for $30 CAD.
I was pleasantly surprised to discover that the AMD Wraith Prism cooler fits perfectly on an AM3 socket. Swapping it in dropped my temps by a solid 20°C compared to the stock cooler—huge improvement. That said, I’m honestly shocked by how much heat the motherboard itself puts out, especially from the VRMs and chipsets.
My Win9x machine is a Socket 754 Athlon 64 running a Wraith Prism from a Ryzen 3700x. AMD kept their cooler measurements the same for a crazy long time.
The 750ti was a decent midrange card that sipped power when released in 2014. But put it into an XP machine and it's a powerhouse that can be powered solely off the PCIe slot. So you could get a cheap or even free early i-series decommissioned business machine, insert one without needing to worry about an under powered PSUs and you have a monster XP machine.
My only concern would be driver overhead with slower CPUs, so we'll see how it ends up performing. Have fun with the build, going back to XP is surprising when you see how few processes and random stuff MS has running in the background compared to Windows 10/11.
Reply 21 of 27, by UCyborg
I still have GTX 750 Ti in my desktop. Bought in 2014 as Radeon HD 4890 couldn't handle Wolfenstein: The New Order. Something more expensive probably wouldn't make sense for an aging PC.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 22 of 27, by Linoleum
Archer57 wrote on 2025-08-16, 18:05:
Linoleum wrote on 2025-08-16, 17:36:
If I am running a FX 6300 that can do 4.1Ghz on boost, would that be feasible to limit cores to 2 and have then run them at 4.1ghz at all time (or at least when games are running)?
Should be. Just be aware that FX6300 is not really full 6 core CPU. It has 3 "modules" with each module containing 2 "cores", which share some components including FPU, L2 cache, etc. So it essentially is 3 core CPU with "Clustered Multithreading".
I am not sure how disabling cores would work, but if you leave one module it would not be great. Probably safer to leave at least 4 "cores", or even all 6. Just have good enough cooler and it'll run at 4.1Ghz all cores...
So far, everything is working perfectly with the MSI 970 Gaming board (AM3+) + Fx 6300; after wasting countless hours trying to use a USB3 port to install WinXP IE. Ugh...
I am trying to disable 2 of the 3 CPU modules while overclocking around 4.0Ghz and I get faulty overclocking BIOS errors almost every time I reboot the system. I'd be curious to know what settings/voltages you are using...
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 23 of 27, by Intel486dx33
HP z400,
HP z800 ,
HP 8000 elite mini tower convertible
or
HP z440
All can run WinXP thru Win-10 fully supported by HP drivers
Or Even Win-11 using Rufus installation tool to bypass system requirements.
See my post:
Re: HP Z800 Time machine build
Reply 24 of 27, by Linoleum
So, this is the final product: EVGA GTX 750ti, 4gb DDR3 1866, FX6300 @3.8ghz, 250gb ssd, 500gb hdd, Sound Blaster X-Fi. MAN this Cooler Master Sniper case is HUGE!!! I never had a case with 200mm fans before...
PS2 30/286, SBP
Reply 25 of 27, by AlexZ
You have just 1 memory stick.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 26 of 27, by Linoleum
AlexZ wrote on 2025-08-23, 14:13:
Yup. I don't really care for that extra 10% (for now)... It's already an overkill.
PS2 30/286, SBP
Reply 27 of 27, by chinny22
While I don't like modern RGB I must admit I'm a sucker for 1 colour LED lighting.
AMD Red as well, very nice looking build
