Voodoo Rush 4440 + Rush information
Reply 20 of 24, by Pr1ha
sdz wrote on 2026-08-21, 08:24:
Next, I tweaked some internal driver parameters (SST96_FT_CLK_DEL SST96_TF0_CLK_DEL SST96_TF1_CLK_DEL SST96_TT_CLK_DEL, can now be set externally with the new driver, same as then could always be set for a Voodoo/Voodoo2 card but never on the Rush for some reason).
What you're doing is amazing!
Is it possible to modify the gamma parameter in the driver so that it can be set externally?
Reply 21 of 24, by sdz
Yes, it should be possible to implement that.
Reply 22 of 24, by sdz
Gamma can now be set externally, eg:
set SST96_GAMMA=1.7
or per channel, eg:
set SST96_RGAMMA=1.7
set SST96_GGAMMA=1.7
set SST96_BGAMMA=1.7
The attachment S1.jpg is no longer available
The attachment S2.jpg is no longer available
This is only supported on the Alliance ProMotion AT25/AT3D. Macronix 2D IC is not supported.
Reply 23 of 24, by Thandor
Very nice work!
Your card looks very clean with very little glue between chips. What is that makes your cards needing less SMD components?
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 24 of 24, by sdz
@Thandor thanks!
There aren't relly less SMD components, they are all on the bottom side of the PCB, and are way smaller than what was used back in the day on the Voodoo Rush.
