Reply 20 of 67, by Shagittarius
- Oldbie
DaveDDS wrote on 2025-09-19, 15:39:Oh... I doubt I actually NEED it ... I'm sure I could assign IP addresses and block the individual systems on my primary router. […]
Shagittarius wrote on 2025-09-19, 14:19:What is your setup like that you need a separate router to stop internet access ...
and block the individual systems on my primary router... I just tend to take
the "easy" way when I can...On my primary router I can block any traffic from the connection port to the
gateway... makes it easy - and if I'm trying something tricky, I can unplug
one cable to make sure they are disconnected from "the world".I happen to have a "box" in my basement with probably nearly a dozen
old routers, was very easy to just use one of those, and as most of
my older systems are near each other, also avoided running long cables.Plus some of my older laptops can't do WPA2 .. so the second router
provides easy wifi access without having to spend days trying to find
(quite probably non-existant) drivers for old hardware.
Thanks for the explanation, I see how the older standards could be of particular use without compromising your main setup.
