Harvester installation problems
Reply 20 of 35, by DustyShinigami
Hmm. Not having much luck getting Windows 98 set up in 86Box. 🙁 It complains the CPU is unworkable or has been changed. And every time I try to boot from the 98 disc image, it just says Disk Boot Failure. I've tried playing with the different controllers, but nothing seems to work. I can't even access FDISK or it doesn't believe it exists.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 21 of 35, by wbahnassi
Check PhilsComputerLabs latest video. It might help.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 22 of 35, by DustyShinigami
wbahnassi wrote on 2025-10-01, 13:21:
Okay, thanks for the tip. I've also installed PCem to try if it fails.
OS: Windows 98 SE
Reply 23 of 35, by DustyShinigami
Right...!
The attachment ass.gif is no longer available
Everything's set up and good to go with 86Box. Now to test the game's installer and see what happens.
OS: Windows 98 SE
Reply 24 of 35, by DustyShinigami
Bingo. Okay, so it does indeed do the same thing on 86Box with 256MB RAM. I lowered it down to 16MB and the error goes away. 😁 So yeah, like I said previously, I would have to look at swapping out the RAM for something much lower. I'll see how high I can take the RAM first before the error comes back. And I'll try installing it with the bare minimum RAM and then see if the game can be played with 256 again.
OS: Windows 98 SE
Reply 25 of 35, by DustyShinigami
Only problem I'm having now is getting past this error when trying to play it...
The attachment 86Box_SbPo7YVzYw.png is no longer available
OS: Windows 98 SE
Reply 26 of 35, by DustyShinigami
Okay, crisis averted. Those runtime errors were because I hadn't added the Soundblaster to my autoexec.bat file. 😁 The game loaded up fine. So yeah, looks like I'll either need to get a small memory module for any games with similar issues, or - I find an alternative memory capper.
OS: Windows 98 SE
Reply 27 of 35, by DustyShinigami
Very interesting. Thanks to this thread, and specifically this post - Re: Limit DOS RAM memory (XMSDSK / HimemX / JemmEx), DOS RAM size limit - if I disable OS/2 Onboard memory > 64M... although I think it comes under something different for me. I think it's OS Select for DRAM > 64MB Non-OS2/OS2...? and then use the LIMITMEM tool - http://lonecrusader.x10host.com/rloew/limitmem.html - it does appear to adjust the total amount of (physical) memory in DOS. I've taken it down to 32MB and 16MB.
Sadly however, the error still happens.
OS: Windows 98 SE
Reply 28 of 35, by DustyShinigami
Bingo! Hopefully... Just tried the option Memory Hole 15M-16M and that fixes the issue! Even if no memory limit is applied and it's using 256MB. 😁
Surprised no one brought that to my attention, to be honest.
Now, that option is available on my 86Box config, but I'm not sure if it's present on my actual PC. I presume it will be though.
Also, setting things back to default and having the full amount of RAM doesn't affect loading up the game after it's installed. 😀
OS: Windows 98 SE
Reply 29 of 35, by SweetLow
DustyShinigami wrote on 2025-10-02, 15:39:
Ok, I bring to your attention that nothing on your screenshots proofs that your really restricted your memory to 16M.
Reply 30 of 35, by DustyShinigami
SweetLow wrote on 2025-10-10, 13:10:
I probably didn't. But it doesn't matter. The important thing is I found an option that can be toggled in the BIOS that helps get around the issue.
OS: Windows 98 SE
Reply 31 of 35, by SweetLow
DustyShinigami wrote on 2025-10-10, 13:29:
And what will you do on the system without such option?
Reply 32 of 35, by DustyShinigami
SweetLow wrote on 2025-10-10, 14:20:
It won't be on another system. The system in question is the system. And I bought this particular motherboard for it's range of options and higher FBS and CPU clock speeds.
OS: Windows 98 SE
Reply 33 of 35, by SweetLow
DustyShinigami wrote on 2025-10-10, 14:55:
And you waited that people have to now how to solve problem of memory limiting on the system instead of just the memory limiting nonetheless?
Reply 34 of 35, by DustyShinigami
SweetLow wrote on 2025-10-11, 21:19:
I'm sorry, what is your problem, exactly? I was trying to find a workaround for the issue and was asking for suggestions/advice. The things suggested didn't work for me (it happens. A lot), but I managed to find something that did. Problem solved.
OS: Windows 98 SE
Reply 35 of 35, by SweetLow
I have no problem at all in restricting memory when I need this. You definitely had.
>I probably didn't.
Of course, things didn't work if you didn't do.
