Reply 20 of 47, by DaveDDS
jude1977 wrote on 2025-10-24, 07:59:
hi i noticed you said FWIW what does that mean and when you said you ran it through DOS 5 was that a machine that's got windows on it and if so what
version of windows and was it a downloaded copy of flight simulator 3 or a retail copy
FWIW = "For What Its Worth"
I was on a DOS-only system - it doesn't have W98 (or even W3.1)
My main reason for testing in this configuration was to confirm that no extender/high memory is used by FS3.
All it wants is conventional DOS memory.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 21 of 47, by DaveDDS
Btw, if you give a link to exactly where you "downloaded" it from, I can confirm that that exact copy works for me.
Reply 22 of 47, by jude1977
hi yes i tried restarting in DOS mode and tried to run the game but with no luck the version of flight simulator 3 I'm using is a downloaded version so maybe that's why its not
working maybe its a bad version I'm using I'm not really Shure
Reply 23 of 47, by Jo22
Hi, the error message could also be related to file compression.
Microsoft was known for compressing executables, so they would take up less space on floppies (and hard disk).
It might be that the decompression routine has memory issues, thus.
But that's just a wild guess. Not sure if that's the real reason.
Reply 24 of 47, by jude1977
interesting may be your wright
Reply 25 of 47, by jude1977
hi these are the 3 links I've been downloading and trying to use I've been trying normal dos and not dosbox
as i wanted to use the program in dos without having to use dosbox
REMOVED
i would be interested to see if these versions download work for you
Reason: Links to abandonware sites
Reply 26 of 47, by DaveDDS
Jo22 wrote on 2025-10-25, 05:52:
Hi, the error message could also be related to file compression. Microsoft was known for compressing executables, so they would […]
I doubt that's the case - I'm testing with the official Micorsoft Distribution diskette (which I bought new back in the day)
So far it's worked everywhere I've tried with a vanilla W98 install (604k conventional free) including with a "memuse" tool
to make the avail. conventional memory about 300k - as well with DOS with only 640k conventional RAM.
I suspect it's either something else loaded in W98 or a corrupt copy of FS.
Reply 27 of 47, by DaveDDS
jude1977 wrote on 2025-10-25, 09:08:
hi these are the 3 links ...
"REMOVED "
Argh... I was assuming it was a legit download from somewhere, maybe
Microsoft had released some of their other DOS stuff like they did for
DOS itself.
I really don't condone distribution of "abandon ware" - but in the interest in figuring out what is going on,
Perhaps you can verify that it works on your own.. What do you have in the way of PCs and emulators available.
I still have a couple DOS systems, and a couple more that I can boot DOS
from floppy on... But I also test DOS stuff with:
- DosBox (native)
- DOS booted in DosBox
- DOS booted in Vmware Player
- DOS booted in PCEM
- W98 booted in PCEM
If you have a system/emulator that can boot DOS, you can get legit images
for a few DOS versions from DBDOS.ZIP on my site.
Then you just need to boot/mount (a copy of) the FS3 diskette and you
should be able to see if it actually works!
Reply 28 of 47, by jude1977
hi
thanks for your reply yes i should of mentioned there downloads sorry about that
I was wondering if you would have a legit copy of flight simulator 3 files you could send me
as I've looked on eBay and cant find a retail copy of flight simulator 3
and I didn't really want to use downloaded copy's of it
or if you know a web site I can download a legit copy of it
regards jude
Reply 29 of 47, by DaveDDS
jude1977 wrote on 2025-10-26, 06:39:
thanks for your reply yes i should of mentioned there downloads ...
Actually you did - you started the thread with "I downloaded ..."
I just assumed that MS had released it (they did after all release DOS itself)
But - as it shows someone elses name at startup, I'm guessing they licensed it, and not developing that version in-house could not just "release" it.
I was wondering if you would have a legit copy of flight simulator 3 files you could send me ...
I have the same problem - I don't have rights to distribute it either. As a livelong software developer who made a good living
by selling my various tools - I tend to be more anal than many about respecting copyright, even on old/obsolete material.
What I *COULD* do is toss together a small program to CRC the disk image, and send it to you along with the CRC it calculated for
an image of my disk - this would tell you if your disk is exactly the same as mine (and original MS distribution copy)
There's no guarantee there aren't possible legit differences -- there might be minor differences in countries or versions...
I could CRC the files on the disk - an you would be able to see "how different" it is - I'd guess that if your is an English copy of
exactly the same version, most of the files would match.
Reply 30 of 47, by jude1977
hi that would be great if you could ide really appreciate it
regards jude
Reply 31 of 47, by DaveDDS
Ok, give me a day or two - I want to do this on an exact copy of my original disk which will take me some time to make (as well as
write the CRC program)
Reply 32 of 47, by jude1977
thanks dave know worries I really appreciated it
many thanks jude
Reply 33 of 47, by DaveDDS
Ok, I tossed this together:
Here is a little DOS tool to help compare two(or more) file sets.
I created this mainly to compare the content of floppy disks, so it does have
some limitations that may come into play comparing larger trees. (max 256files,
32k name buffer)
To avoid seeking back and forth excessively on the floppy, FCK reads the
directory only once and buffers it's information, then read/calculates CRC
for each file.
Please note that this was a "quick and dirty" tool that I woite in an hour,
it's not particularly pretty source code ... also please refer to my notes in
the "source code" section of my site before complaining about my style!
I have also included FCK.DVM, if you don't have a DOS system, you can run
on newer windown with DunfieldVirtualMachine (available on my site)
I included the above text, the C source code, a DOS .COM and a .DVM which runs
under my virtual machine (mainly how I run simple stuff in WinBlows)
You can get it from: dunfield.themindfactory.com/Drop/FCT.ZIP
This is it's output on my FS3 diskette.
1988-03-22  10:26:54        1627  2300F92A  FLSIM\_LA4.DEM
1988-03-24 15:48:38 672 59E7B05E FLSIM\F6HSENS
1988-03-29 16:13:54 672 4E89A6CD FLSIM\F6CSENS
1988-04-05 14:15:36 672 AF8CA7BC FLSIM\F6MSENS
1988-04-06 14:06:16 8197 A93CF78E FLSIM\_LB2.DEM
1988-04-06 15:29:12 672 1116D990 FLSIM\F6SENS
1988-04-08 10:08:18 1334 6E4CCFE3 FLSIM\FORM1.DEM
1988-04-08 10:08:20 1633 74EB69FA FLSIM\FORM2.DEM
1988-04-08 10:08:24 2036 E0257633 FLSIM\FORM3.DEM
1988-04-08 10:08:26 1088 EAD332DF FLSIM\FORM4.DEM
1988-04-08 10:08:28 1610 287C236D FLSIM\FORM5.DEM
1988-04-08 10:08:30 902 47549777 FLSIM\FORM6.DEM
1988-04-08 10:08:32 1228 2B72CF16 FLSIM\FORM7.DEM
1988-04-08 11:23:56 6680 FF9173F1 FLSIM\F6
1988-04-08 11:27:10 12234 BA2384FD FLSIM\F6C
1988-04-08 13:21:58 17500 ECA9818A FLSIM\F6H
1988-04-08 15:36:04 6504 7524B7D1 FLSIM\_LA7.DEM
1988-04-14 15:36:48 1027 EE60833F FLSIM\_LB1.DEM
1988-04-14 15:37:00 764 6ED571D3 FLSIM\_LB3.DEM
1988-04-14 15:37:06 2261 197E0D3C FLSIM\_LB4.DEM
1988-04-14 15:37:24 705 45776E8A FLSIM\_LA1.DEM
1988-04-14 15:37:28 610 9CF7C33A FLSIM\_LA2.DEM
1988-04-14 15:37:30 1111 BF88D1A9 FLSIM\_LA3.DEM
1988-04-14 15:37:46 1053 08774E46 FLSIM\_LE1.DEM
1988-04-14 15:37:50 522 9B9432DB FLSIM\_LE3.DEM
1988-04-14 15:37:52 626 C38B0D58 FLSIM\_LE4.DEM
1988-04-14 15:37:54 780 7FC737AF FLSIM\_LE5.DEM
1988-04-14 15:37:58 940 358A18FC FLSIM\_LE6.DEM
1988-04-14 15:38:00 1165 4037F13B FLSIM\_LE7.DEM
1988-04-14 15:46:24 8 B32813CB FLSIM\FS.BAT
1988-04-14 17:41:02 3002 11CCAB32 FLSIM\_LA5.DEM
1988-04-18 8:44:04 11 0BF50F07 FLSIM\CF.FS3
1988-04-20 12:22:52 3287 92CA7E48 FLSIM\_LA8.DEM
1988-04-20 12:37:06 880 EABCD2F9 FLSIM\_LE2.DEM
1988-04-21 11:32:44 13 73E06A25 FS.BAT
1988-04-22 10:48:38 2325 F2CE65F3 FLSIM\_LBA.DEM
1988-04-22 15:05:08 1131 E346B60D FLSIM\_LB8.DEM
1988-04-26 16:23:46 1141 99594EEB FLSIM\_LB6.DEM
1988-04-26 16:24:50 3165 059B3B10 FLSIM\_LB7.DEM
1988-04-29 15:17:16 518 C8DAEC66 FLSIM\WW1.MOD
1988-04-29 15:17:18 518 2A9D18E3 FLSIM\FORM1.MOD
1988-04-29 15:17:18 518 A0F404CA FLSIM\FORM3.MOD
1988-04-29 15:17:18 518 B0C1BA4C FLSIM\FORM4.MOD
1988-04-29 15:17:18 518 E6D04621 FLSIM\FORM2.MOD
1988-04-29 15:17:20 518 1BE3BB3D FLSIM\FORM5.MOD
1988-04-29 15:17:20 518 A86747E1 FLSIM\FORM6.MOD
1988-04-29 15:17:20 518 D997B73F FLSIM\FORM7.MOD
1988-04-29 15:17:24 518 E2C9EBC7 FLSIM\EFISDEMO.MOD
1988-04-29 15:17:26 518 19977BD6 FLSIM\MODE2.MOD
1988-04-29 15:17:28 518 99BA9B53 FLSIM\MODE4.MOD
1988-04-29 16:23:36 518 CFFC9D66 FLSIM\_LB1.MOD
1988-04-29 16:23:38 518 4812270B FLSIM\_LB2.MOD
1988-04-29 16:23:38 518 FF0E8371 FLSIM\_LB4.MOD
1988-04-29 16:23:40 518 598A3531 FLSIM\_LB5.MOD
1988-04-29 16:23:40 518 6D0EBE18 FLSIM\_LB6.MOD
1988-04-29 16:23:40 518 B7329007 FLSIM\_LB7.MOD
1988-04-29 16:23:42 518 092D7E86 FLSIM\_LA1.MOD
1988-04-29 16:23:42 518 1D3496FE FLSIM\_LB8.MOD
1988-04-29 16:23:42 518 774884C5 FLSIM\_LBA.MOD
1988-04-29 16:23:42 518 7F6461DE FLSIM\_LB9.MOD
Show last 77 lines
1988-04-29  16:23:44         518  8068C247  FLSIM\_LA2.MOD
1988-04-29 16:23:44 518 9A0F30D5 FLSIM\_LA4.MOD
1988-04-29 16:23:44 518 C91BB566 FLSIM\_LA3.MOD
1988-04-29 16:23:46 518 0CFC7381 FLSIM\_LA7.MOD
1988-04-29 16:23:46 518 1F20EEE5 FLSIM\_LA5.MOD
1988-04-29 16:23:46 518 3023F879 FLSIM\_LA6.MOD
1988-04-29 16:23:48 518 15A1E07E FLSIM\_LE3.MOD
1988-04-29 16:23:48 518 5189F657 FLSIM\_LE1.MOD
1988-04-29 16:23:48 518 ABA84E78 FLSIM\_LA8.MOD
1988-04-29 16:23:48 518 AD3C4DC7 FLSIM\_LE2.MOD
1988-04-29 16:23:50 518 166E47D3 FLSIM\_LE6.MOD
1988-04-29 16:23:50 518 7C65137D FLSIM\_LE5.MOD
1988-04-29 16:23:50 518 80D0B4E8 FLSIM\_LE4.MOD
1988-04-29 16:23:52 518 6133FE86 FLSIM\_LE7.MOD
1988-05-02 17:33:10 1264 9FE79873 FLSIM\_LB9.DEM
1988-05-02 17:37:34 684 F2F017BD FLSIM\_LB5.DEM
1988-05-03 13:03:14 10881 F8C7FC6D FLSIM\FS3.DEM
1988-05-09 7:58:48 518 8E65955A FLSIM\MODE1.MOD
1988-05-09 14:05:32 160768 CBBA7D51 FLSIM\F1
1988-05-09 15:05:00 518 2091B295 FLSIM\_LB3.MOD
1988-05-09 18:23:24 1521 B7116A91 FLSIM\_LA6.DEM
1988-05-10 12:11:24 14 F4A7553B FS3.BAT
1988-05-10 12:14:16 618 73E00EC5 README
1988-05-12 11:55:08 518 EB32C61D FLSIM\CROP.MOD
1988-05-13 15:22:06 3245 B58E938F FLSIM\CONVERTS.EXE
1988-05-13 15:22:32 16606 01869D20 FLSIM\FOREIGN.FS3
1988-05-13 15:24:30 1574 B57550F8 FLSIM\STR.FS3
1988-05-14 9:02:40 889 5F97C19E FLSIM\_LB3.FLB
1988-05-14 9:02:40 1178 0D54A6C8 FLSIM\_LB1.FLB
1988-05-14 9:02:42 1125 C2D26FB4 FLSIM\_LA1.FLB
1988-05-14 9:02:42 1128 B11C556B FLSIM\_LB5.FLB
1988-05-14 9:02:42 1179 D166CBA1 FLSIM\_LB7.FLB
1988-05-14 9:02:42 1407 109CE49E FLSIM\_LB9.FLB
1988-05-14 9:02:42 1467 C9EC3917 FLSIM\_LB8.FLB
1988-05-14 9:02:42 1719 BA78905C FLSIM\_LB4.FLB
1988-05-14 9:02:42 1812 A53B1235 FLSIM\_LBA.FLB
1988-05-14 9:02:44 943 D85590A3 FLSIM\_LA2.FLB
1988-05-14 9:02:44 1002 47ACCA2A FLSIM\_LA3.FLB
1988-05-14 9:02:44 1156 13471F4B FLSIM\_LA8.FLB
1988-05-14 9:02:44 1363 5363ECAC FLSIM\_LA5.FLB
1988-05-14 9:02:44 1412 9254FE7A FLSIM\_LA4.FLB
1988-05-14 9:02:44 1586 6090CB2C FLSIM\_LA6.FLB
1988-05-14 9:02:44 1965 9AC4830C FLSIM\_LA7.FLB
1988-05-14 9:02:46 1152 09A90BF5 FLSIM\_LE4.FLB
1988-05-14 9:02:46 1234 EFDD1EFD FLSIM\_LE3.FLB
1988-05-14 9:02:46 1388 67450F74 FLSIM\_LE1.FLB
1988-05-14 9:02:46 1532 AA98888C FLSIM\_LE2.FLB
1988-05-14 9:02:46 1556 A6A5F5BA FLSIM\_LE5.FLB
1988-05-14 9:02:46 1753 C5839B23 FLSIM\_LE6.FLB
1988-05-14 9:02:46 1785 FF667665 FLSIM\_LE7.FLB
1988-05-15 15:31:32 778 698DD91E FLSIM\KB1.KBD
1988-05-15 15:31:44 873 4E424EEB FLSIM\KB2.KBD
1988-05-15 15:31:58 1274 C3A43C3B FLSIM\KB3.KBD
1988-05-15 15:32:14 6293 37DDD796 FLSIM\SIM1.SIM
1988-05-15 15:32:28 7113 A8087730 FLSIM\SIM2.SIM
1988-05-15 15:32:44 6453 3E3E35DA FLSIM\SIM4.SIM
1988-05-15 15:32:58 3690 F062A982 FLSIM\WW1.APL
1988-05-15 15:33:12 5405 D02BA722 FLSIM\CROP.APL
1988-05-15 15:33:26 1911 EB57A86F FLSIM\FORM.APL
1988-05-15 15:33:42 10659 84E9CAAE FLSIM\MULTI.APL
1988-05-15 15:33:56 4306 89A39E73 FLSIM\ANALYSIS.APL
1988-05-15 15:34:10 3615 EB92AD2B FLSIM\LESSONS.APL
1988-05-15 15:34:26 18578 1E6B6929 FLSIM\EGA1.GRA
1988-05-15 15:34:42 19026 AF2C998F FLSIM\CGA1.GRA
1988-05-15 15:35:00 23650 8351079A FLSIM\PS21.GRA
1988-05-15 15:35:14 19458 649CD5A4 FLSIM\CGA2.GRA
1988-05-15 15:35:30 21106 33AEFF62 FLSIM\TGA1.GRA
1988-05-15 15:35:46 18370 C3AB7A21 FLSIM\EGB1.GRA
1988-05-15 15:36:00 19298 A213AC03 FLSIM\INCLR.GRA
1988-05-15 15:36:16 19746 7054B5A1 FLSIM\MONO.GRA
1988-05-15 17:04:22 660 356C6A94 FLSIM\_LB2.FLB
1988-05-15 18:20:04 1294 7549C94B FLSIM\_LB6.FLB
1988-05-16 11:43:04 83285 C6EBEBA9 FLSIM\FS3.EXE
1988-05-17 11:08:12 13201 E765F573 FLSIM\README.DOC
Newest=1988-05-17 11:08:12
Oldest=1980-00-00 0:00:00
Reply 34 of 47, by jude1977
hi that's great many thanks I will see how I go
Reply 35 of 47, by jude1977
hi thanks for looking at the files I'm not shore what to do really i thought you might of been able to send me a actual copy
but thanks again for looking at the files
regards jude
Reply 36 of 47, by DaveDDS
Just run my tool on the diskette and capture the output:
> FCT B:\ >mylist.txt
Then compare the list generated with the one I gave you.
Hopefilly the date, time, size and CRC will all match for files of the same name.
date and time don't matter as much, but if size and CRC match yours, the files are identical.
Reply 37 of 47, by DaveDDS
To keep the thread informed, this happened "offline":
The person privately sent me the link where they had downloaded FS3,
so I downloaded it and created two 5.25 360k floppies, which during my testing
got their content copied to a 3.5" HD - after completing the testing, I deleted
the .ZIP download (and the files I had extracted from it), and bulk erased the
three actual floppies I made - In other words I did not retain any copy of the
downloaded game!
-- This is my test results/response --
My copy is on a single 720k 3.5" disk. The one you gave a link to was
two 5.25" 360k disks. My system has a 3.5"HD disk as drive A: and a 5.25"HD
as drive B:
So I did this, using the link you sent (which had two images called
"PROGRAM.IMG" and "SCENERY.IMG"):
Formatted a new/blank 3.5" disk (1440k) in drive A:
Then went to the DOS prompt (in W98 - not reboot in DOS)
C:\> A:
A:\> MD FS3
A:\> CD FS3
- Inserted "PROGRAM" disk in drive B:
A:\FS3> copy B:*.*
- Inserted "SCENERY" disk in drive B:
A:\FS3> copy B:*.*
A:\FS3> FS
The flight simulator loaded and ran properly under Win98!
I was able to "fly around" a bit!
Reply 38 of 47, by DaveDDS
DaveDDS wrote on 2025-10-28, 02:10:
...The person privately sent me the link where they had downloaded FS3 ...
I may have been mistaken about this - looking at settings, I see that Vogons was set to message me replies to my posts.
(which I've now turned off)
If this is what happens, Vogon moderators might want to be aware that "forbidden" material they remove from posts can still
make it through! (not sure how to easily fix this - perhaps don't message responses till a moderator has viewed it - assuming
that moderators do eventually look at all new posts - otherwise why mention this here!)
Reply 39 of 47, by jude1977
hi all I've tried getting the program to run with instructions given above but its way to complicated for me I'm not very computer savvy I guess
any way thanks all
