Accuracy w/ CRT monitor
Reply 20 of 22, by Mov AX, 0xDEAD
leileilol wrote on 2026-05-24, 15:29:
When I used a CRT on DOSBox in the 00s, fullresolution=original was the way to go. Text mode wasn't accurate (unless you pretend it's a laptop with a canonical 640x400 text mode),
Adding 640x400 to CRT monitor resolution table (Custom Resolution Utility) will make fullscreen textmode accurate too, only refreshrate can be different. OR adding "original" 720x400x70Hz to table, but it doesn't always work.
download/file.php?mode=view&id=242880
Reply 21 of 22, by leileilol
These modes had still existed on windows drivers then, I didn't have to add in any modes or any sort of INF hackery.
Reply 22 of 22, by Mov AX, 0xDEAD
leileilol wrote on 2026-05-26, 18:24:
PnP CRT monitors don't export 720x400 or 640x400 as supported resolution, so Windows (i mean Vista+) will never choose it
