Reply 20 of 20, by luk1999
Hellvis wrote on 2026-06-09, 21:14:
By fine, I mean anywhere between 10-30 FPS, mostly hanging around 17 FPS depending on environment and number of enemies in the firefight. It means I can "enjoy" it the same way i "enjoyed" beating American McGee's Alice on my second rig (Celeron 500MHz, ATI Rage 128 Pro).
Thank you all so much for help and suggestions!
Did you try to run RTCW on Celeron rig? It should be far more enjoyable for sure because it needs fast CPU while graphic card doesn't matter that much. 😀
I remember playing it soon after release on my Duron 700 with 128 MB RAM and slightly overclocked Riva TNT1 card. And it was pretty nice experience in 640x480 16b with just some light swapping.
Friend of mine run it on Celeron 466 / BX / 128 MB RAM / GF2 MX and it worked significantly worse albeit it was still playable.
P4 3.4E, ASUS P4C800-E Dlx, 1 GB, X800 PRO 256 MB AGP, SB Audigy, XP SP2
P3 800, AOpen AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
P233MMX, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
