Reply 20 of 20, by Pling
- Newbie
Hello everyone,
While testing my ISA VGA cards for compatibility with the GALAXEUS engine, I found a 16-bit ISA VGA card that completely blows everything else out of the water:
the MCT-VGA-16 (Chipset: TD3588A).
I'm getting 544 x 480 at 89 Hz with solid 89 FPS on my 386SX test board!
https://www.youtube.com/watch?v=MDW9Y0tLP48
I think this is slowly reaching the absolute limit for ISA VGA cards.
In summary, I only encountered problems with the GALAXEUS engine on one of the tested VGA cards:
The Ahead AVGA/DELUXE (BIOS v2.03) did not set the Set/Reset registers to 0 when initializing Mode 12h via the VGA BIOS.
The GALAXEUS engine now sets these registers itself, which solves the problem.
I was also able to optimize the size. The DOS binary is now only 54.7 KB. Everything is included: audio samples, sprites, all in a monolithic .COM file.
These are the cards I tested, along with the respective Hz and FPS values achieved:
MCT-VGA-16 / TDVGA 3588 (TD3588A) 16-bit ISA 88 Hz / 88 FPS Top!
Avance Logic ALVGA 2101c 16-bit ISA 79 Hz / 79 FPS
Tseng ET3000AX (P/N 3071 REV A, ARA) 16-bit ISA 79 Hz / 79 FPS
Tecmar VGA AD 939589 (ET3000AX) 16-bit ISA 79 Hz / 79 FPS Fail @ 77 Hz, stable again @ 78-79 Hz
Realtek RTVGA 2 91024B 16-bit ISA 78 Hz / 78 FPS
Ahead AVGA/DELUXE 16-bit ISA 78 Hz / 78 FPS
OAK OTI-VGA Bi034D 8-bit ISA 78 Hz / 78 FPS
OAK OTI-067 16-bit ISA 78 Hz / 78 FPS
OAK OTI-087 16-bit ISA 78 Hz / 78 FPS
OAK OTI-077 RT-3202 16-bit ISA 78 Hz / 78 FPS
Acumos AVGA2 (CL-GD5402) 16-bit ISA 78 Hz / 78 FPS
Cirrus Logic CL-GD540x/542x 16-bit ISA 78 Hz / 78 FPS
Cirrus Logic CL-GD520A (CVGA) 16-bit ISA 78 Hz / 78 FPS
OCTEK AVGA-20H (CL-GD542) 16-bit ISA 78 Hz / 78 FPS
OAK OTI-067B 16-bit ISA 78 Hz / 78 FPS
Cirrus Logic GD542x-V4-009 16-bit ISA 78 Hz / 78 FPS
Jaton TVGA 8900CL (KT-TVGA89CL-V1) 16-bit ISA 78 Hz / 78 FPS
Peakock 59-676L-0001 XP676L (WD90C11-LR) 16-bit ISA 77 Hz / 77 FPS
MTV-8908C VGA 16T/89C P/N 10760 16-bit ISA 77 Hz / 77 FPS
Cardex TSVGA 9015-31 (ET4000AX) 16-bit ISA 77 Hz / 77 FPS
Octek EVGA-8 8-bit ISA 77 Hz / 77 FPS
Western Digital Paradise VGA Plus 8-bit ISA 77 Hz / 77 FPS
OCTEK PVDA1D 16-bit ISA 77 Hz / 77 FPS
Paradise PVGA1A JK2 16-bit ISA 77 Hz / 77 FPS
Cirrus Logic CL-GD5402 / Acumos AVGA2 16-bit ISA 77 Hz / 77 FPS
Trident 9016X2/4 LT2 16-bit ISA 77 Hz / 77 FPS
Trident TVGA 8900C 16-bit ISA 77 Hz / 77 FPS
Tseng ET4000AX P/N 3081 REV C, ARA 3081 16-bit ISA 76 Hz / 76 FPS
Gainward / CARDEX TSVGA 16-bit ISA 76 Hz / 76 FPS
Genoa Super VGA 8800 16-bit ISA 75 Hz / 75 FPS
