Reply 20 of 23, by Neville
The new version of the program (alpha 50) has flagged pretty much all my profiles. They were imported from an old DBGL package and switched to use DOSBox Staging, but previously they only had a few problems, such as a few using cputype=pentium_slow or ems=false, that has changed to ems=off.
Now the issue seems to be the capture folders and, in some cases, the cycles setting, that has changed to cpu_cycles.
But since this would involve manually editing +50 profiles I can't see myself doing it.
Is there any chance of making these updates automatically in the future?
Reply 21 of 23, by mrmercy82
@Neville, the solution for your issue is found in your uploaded screenshot and it's actually the reason why I wanted this feature it to be in DBGL EE:
You see the solution column? For those two issues, DBGL EE has the corresponding solutions. Since the certain game/demo is already highlighted together with the two solutions...
Click on "Next: Preview" to see how DBGL EE wants to solve it. It presents you the necessary changes to your .conf and you can just click Confirm/Okay and that's it.
Similarily, select all the profiles that are flagged and then choose "Check profiles". You could basically do the same step to change all flagged issues at once. Remove the selection from any issue that you dont want to be solved.
Reply 22 of 23, by Neville
Ahhhh... I should inform myself better. I guess I keep expecting DBGL EX to behave just like DBGL did.
EDIT: Solved most problems. The profiles still worked, but who knows if they could stop working in the future, depending on DOSBox-Staging future changelogs.
I've ended up with a few profiles that still report problems, but nothing serious. If that, I think profiles that use the Gravis UltraSound but there is no C:\ULTRASND folder present should not be reported. Most games that support the UltraSound don't actually need the drivers to be installed.
Reply 23 of 23, by mrmercy82
Yeah, the new features might be a bit overwhelming. I am planning to add tutorials to DBGL at a later stage. For any flag you dont want, you can choose to hide it. And now while I am typing this I think I will come up with another setting that allows to hide certain standard notes (as the GUS one).
Another alternative would be to add a mount line in the [autoexec] section in the the main dosbox.conf where you just mount the ULTRADIR on, say letter U and then change the ultradir setting to U:\ULTRADIR. Maybe that one could work since it would affect all profiles associated with that dosbox.conf.
