Reply 20 of 26, by nezwick
- Newbie
wierd_w wrote on 2026-11-13, 03:42:One of the approaches to getting darker / bolder prints from dotmatrix is to have the printer itself inverse-linefeed back up th […]
One of the approaches to getting darker / bolder prints from dotmatrix is to have the printer itself inverse-linefeed back up the page, reposition the carriage over already-printed areas, then print the same image again in exactly the same place. This is fully within the capabilities of an ESC/P language dotmatrix printer.
(Command 'ESC JN' does inverse linefeed, and moves moves the carriage UP the page. It can also just position directly and arbitrarily for graphics, With ESC $, (absolute position H), and ESC ( V (absolute position V). Not all commands are available on all esc/p printers though. For ones lacking absolute position, backspace/forwardspace, and linefeed/reverse linefeed have to suffice.)
(Full command reference here)
https://files.support.epson.com/pdf/general/escp2ref.pdf
Doing this more than 2x, even on cardstock, can turn the paper 'fuzzy', 'bulged', or 'wrinkly', though.
(Mostly mentioned because vintage software like Br0derbund's 'The Print Shop' has builtin functionality to do such overprinting, and could produce damaged paper if used wrecklessly.)
For re-inking, I mean exactly that. There are liquid inks that resist drying out that are meant for self-inking stamp pads, that can be used for this purpose.
You explicitly need to use oil based stamp inks though, like this stuff.
https://www.amazon.com/Black-Oil-Based-Stamp- … /dp/B0782YY5RD/
Color ribbons are too fiddly to re-ink though.
Most of the programming mentioned here is way over my head (programming and math have never been strengths of mine) but I appreciate the discussion nonetheless. One day I will do a deep dive into how to control the printer through programming. It actually sounds really fun!
FWIW, my printer is a Citizen GSX-140+. It does support color printing, though I currently only have black ribbons. Typically I have to use an Epson LQ-850 driver, but I found WordPerfect does actually have a choice for the GSX-140 (both color and black) so I was able to use that.
Thanks for recommending that black ink. I just ordered it. I've been curious about properly re-inking these ribbons for a while, but was too hesitant about what ink to buy. That should help the quality of the printouts quite a lot.
XP: A64 3000+ S754 / 2GB DDR / 500GB SATA / Audigy1
2K: AXP 1700+ @ 1900+ / 1GB DDR / 120GB IDE / X800XL / Audigy 2ZS
98SE: Duron 900 / 512MB SDR / 20GB IDE / Voodoo3 3000 / Vortex2
95: P200 MMX / 128MB SDR / 6GB IDE
DOS: NEC PowerMate 1 / 286 / 640k
