Reply 20 of 21, by wd
wd
Offline
DOSBox Author
Thanks, i rewrote it a bit as several mappings are defaulted
to those values already, maybe you can recheck the entries for
KP5/KP6 as they don't seem to fit.
Maybe the print key is handled in a different way, as sc0 is
usually sent when SDL doesn't know what to do (the current
implementation uses the symkey then).
sdlkey_map[0x61]=SDLK_UP;sdlkey_map[0x66]=SDLK_DOWN;sdlkey_map[0x63]=SDLK_LEFT;sdlkey_map[0x64]=SDLK_RIGHT;sdlkey_map[0x60]=SDLK_HOME;sdlkey_map[0x65]=SDLK_END;sdlkey_map[0x62]=SDLK_PAGEUP;sdlkey_map[0x67]=SDLK_PAGEDOWN;sdlkey_map[0x68]=SDLK_INSERT;sdlkey_map[0x69]=SDLK_DELETE;sdlkey_map[0x5C]=SDLK_KP_DIVIDE;sdlkey_map[0x5A]=SDLK_KP_ENTER;sdlkey_map[0x5B]=SDLK_RCTRL;sdlkey_map[0x5F]=SDLK_PAUSE;// sdlkey_map[0x00]=SDLK_PRINT;sdlkey_map[0x5E]=SDLK_RALT;sdlkey_map[0x40]=SDLK_KP5;sdlkey_map[0x41]=SDLK_KP6;
