compiling problem of franpa
Reply 20 of 131, by franpa
When working on Windows, you might want to save a lot of effort and just use the SDL (and optionally SDL_net) .DLL files included with the latest official DOSBox release, as compiling SDL with full options (e.g. DirectX support) is a bit involved. There are also pre-built .DLL files on the SDL web site (Runtime Libraries -> Win32) that you can try at
it says i didnt need to... but i trust you so i will look.
nope it wont work 😜 http://i63.photobucket.com/albums/h133/franpa … untitled-12.png and i followed these http://www.libsdl.org/extras/win32/mingw32/README.txt
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 21 of 131, by wd
Rank DOSBox Author
DOSBox Author
Use ./autogen.sh before.
Reply 22 of 131, by franpa
er, same issue... where do i put the dll files? and er no success still with compiling my own sdl.
my website
Reply 23 of 131, by wd
Rank DOSBox Author
DOSBox Author
You don't put any dlls anywhere. Get the sdl sources, read their INSTALL
file thing and go through that step by step. That might or might not
require ./autogeh.sh, but will require ./configure and make to install SDL.
Reply 24 of 131, by franpa
http://www.libsdl.org/faq.php?action=listentr … s&category=4#42
says to go to the sdl folder and type ./configure but that says no such file or folder.
edit: do i need the runtime library?
my website
Reply 25 of 131, by MiniMax
Rank Moderator
Moderator
This thread is out of control.
_________________
Reply 26 of 131, by franpa
edited above post.
yea, well... once i learn how to compile this ill consider updating the wiki... then maybe someone could extract all posts relating to me from here and putting them in a new thread?
my website
Reply 27 of 131, by Qbix
Rank DOSBox Author
DOSBox Author
The compiling stuff should be split off.
Water flows down the stream
Reply 28 of 131, by gulikoza
configure is only needed if no Makefiles are present.
SDL-devel-1.2.11-mingw32.tar.gz already has a Makefile so you need only to type make (actually make native)
http://www.si-gamer.net/gulikoza
Reply 29 of 131, by franpa
Franpa@PAUL ~/sdl-1.2.11
$ make native
make install prefix=/usr
make[1]: Entering directory `/home/Franpa/sdl-1.2.11'
make[1]: `install' is up to date.
make[1]: Leaving directory `/home/Franpa/sdl-1.2.11'
then when i go to configure the dosbox source i get
checking for sdl-config... no
checking for SDL - version >= 1.2.0... no
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
configure: error: *** SDL version 1.2.0 not found!
i think i need to change the path variable to point to the dll file included in dosbox 0.70 but how do i do this?
my website
Reply 30 of 131, by gulikoza
delete the install file 😀 (this is actually SDL fault, install should be uppercased)
Reply 31 of 131, by franpa
ln: creating symbolic link `/usrbin/sdl-config' to `i386-mingw32msvc-sdl-config': No such file or directory
make[1]: *** [install] Error 1
make: *** [native] Error 2
my website
Reply 32 of 131, by gulikoza
Missing / in the Makefile
@ln -sf i386-mingw32msvc-sdl-config $(prefix)bin/sdl-config
should be
@ln -sf i386-mingw32msvc-sdl-config $(prefix)/bin/sdl-config
Reply 34 of 131, by franpa
ok, that makes no difference to the crash gulikoza.
my website
Reply 35 of 131, by franpa
why (in his post and not this quote) does the space at the end contain this link?
Re: Dosbox 0.70 is out!
my website
Reply 36 of 131, by franpa
am i allowed to edit the makefile with notepad? if i add a space after the string of text im asked to edit then delete it then do a search for that string, the search will fail.
my website
Reply 37 of 131, by gulikoza
I have no idea what you are trying to say...what space?
Yes, you can edit the Makefile with notepad, but it's in unix format so convert it first:
unix2dos -o Makefile
Reply 38 of 131, by franpa
i don't have to convert back to unix do i?
and er, copy the blank spot and paste it somewhere to see that link.
my website
Reply 39 of 131, by wd
Rank DOSBox Author
DOSBox Author
Funny, how did it develop that you're trying to edit makefiles? If that
doesn't work out try different SDL sources, like the one from
http://www.libsdl.org/download-1.2.php
and go through the full ./autogen.sh + ./configure + make procedure.
And no, you normally don't have to convert it back to UNIX line endings.
