Reply 20 of 27, by Radicator
I am trying to install the cd version of flashback but now the install freezes in dosbox 0.73. I am using the latest freeware version of xxcopy and have followed the instructions for installing it in dosbox. After entering in "install c fb", I get the following message:
XXCOPY == Freeware == Ver 2.93.1 (C)1995-2006 Pixelab, Inc.
Create the new directory, C:\FB\INSTALL.EXE (Yes/No)?
At that time, dosbox freezes up and I have to kill dosbox. Any suggestions?
Reply 21 of 27, by rcblanke
Maybe try to perform the command
SET COPYCMD=/Y
before installing.
Reply 22 of 27, by Radicator
I tried that and still get the same thing.
Reply 23 of 27, by Radicator
The answer was in front of me all of the time. Another way to get the flashback cd to use xcopy, all you have to do is run the install.bat in windows command and exit the game configuration menu. After that you copy the fb directory to your dosbox game directory and run the install.exe from the fb directory. If your CDrom drive is a different letter in dosbox, you have to edit "go.bat" in the fb directory to change it to the drive letter of your mounted cdrom drive in dosbox. Now I have sound and music with mt-32 selected as the midi device. I wonder if this helps other games that install with xcopy. Please do tell.
Reply 24 of 27, by SKARDAVNELNATE
Can someone provide a better link? I don't see an XXCOPY16.EXE in the ZIP file.
Reply 26 of 27, by zerodiagonal
Going through my old .vfd archives (personal backups from my originals; not pirated versions), I found out that STEEL EMPIRE does rely on XCOPY to install.
My workaround was simple: just monut the vfd files and xcopy'ing them using the XP Command prompt, Doxbox'ing the hdd folder for accurate gameplay.
(yeah, this is an old thread but just wanted to add that game to the list)
Reply 27 of 27, by janskjaer
SHRAK for Quake, has the same issue.
There is a binary (SHRAK\ST.EXE) which makes an internal call to XCOPY with /E and /V parameters, so it can't easily be modified as it could be if the binary was a batch file.
I extracted xcopy.exe from Freedos' bin directory, and re-located it within a sub-directory of the dosbox directory, then pointed to this directory within the PATH environment variable in the .conf file, as mentioned in the steps of page 1.
This solved the issue and SHRAK could be installed.
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
