Reply 20 of 29, by dovonob
Set timed=false in dosbox.conf. Or don't change the cycles ingame.
think i've tried the timed thing but I'll double check when i get home and report my findings, as for the not changing the cycles, do you mean don't change them and start the game off on a higher cycle or just not to go over 3500 cycles, cause that just makes the game unplayable.
I will get this working.......
Although i might sound frustrasted with this i will say any game i've tried that doesn't involve a joystick has worked near perfect for me, so I am loving dosbox and the work you guys have done, just typical it's always your favourite game that doesn't quite work right with emulators (perfect dark 🤣 )
