Zombieville
Reply 20 of 27, by zelenog
I found what the problem was - my iso didn't copy all the files completely (only 96 %).
You can close this post now.
Thanks for your help 😀
Reply 21 of 27, by zelenog
Hi again,
I forgot how to properly type "freesize" command in DosBox.
Could you give me an example how to do it.
When I did it properly before, it game me "200 mb allocated" or something like that.
When I did it now, it gave me "illegal command" message.
Also, do I type "freesize" command before "mount c c:\" command?
Thanks in advance!
Reply 23 of 27, by cuttock
Hi gang. While the game installed fine, and starts up fine, all the choices used in the "machine=xxx" area of the DosBox conf. file leads the game to play with a greenish hue. I then tried svga_et4000 and svga_et3000, and the colors of the intro and logo look fine, but when I begin the game, it crashes. I have noticed this "green hue" for some other games, as well. Is there a reason for this?
Reply 25 of 27, by cuttock
Hi Domoius. My system? I am using DosBox 0.74 on Mac OSX 10.6.5.
Reply 27 of 27, by cuttock
Thank you, Dominus. I resolved it by trying the game on VMWare fusion Winows XP/DOSBox 0.74. Worked fine.
I also tried a few other games, like Archimedian Dynasty, and got similar results. Thanks for this.
