Reply 20 of 56, by SoftCat
wrote:Nevermind, I've hex-edited the com file - it works the same as on CGA.
Your real CGA and Hercules works same as on DOSBox?
For Hercules: hercules.zip
I meant real Hercules works same as real CGA. I'm preparing a patch for DOSBox.
1+1=10
Patch for display address.
1+1=10
Negative scrolling values example: il.zip
CGA, EGA, VGA and SVGA test program: il.com
Hercules test program: il_h.com
Real VGA video: il.gif
Before Page 0 must be Page 7.
wrote:Patch for display address.
Could you share DOSBox 0.73 compilation with this patch?
CGA has only 4 pages, Hercules only one.
1+1=10
wrote:CGA has only 4 pages, Hercules only one.
My russian IBM PC "Electronika MS-1502" with CGA card has 32K of video RAM (B800:0000 -- B800:7FFF). 8 pages in text mode 80 x 25 and 16 pages in text mode 40 x 25.
Tests for 4 pages CGA and one page Hercules.
SuperCGA 😀
Wikipedia says 16k RAM.
1+1=10
Patch for text mode memory wrapping, also partially fixes the game 'ICON' with machine=CGA.
1+1=10
Again bug.
5) Incorrect scroll for positive values of registers 0Ch, 0Dh of port 3D5h on CGA and VGAONLY machines (slow reaction of scroll).
See hs3.zip
Test program: hs3.com
Results:
hs3_vgaonly.gif -- DOSBox video of vgaonly machine incorrect scroll (slow reaction of scroll)
hs3_vgaonly.png -- DOSBox screenshot of vgaonly machine
hs3_svga_s3.gif -- DOSBox video of svga_s3 machine correct scroll (normal reaction of scroll)
hs3_svga_s3.png -- DOSBox screenshot of svga_s3 machine
Can't reproduce - do you use some odd cycles values?
1+1=10
wrote:Can't reproduce - do you use some odd cycles values?
I use even and odd values for registers 0Ch (hi byte), 0Dh (lo byte) of port 3D5h. My values are: 7B1h, 7B2h, 7B3h, ..., 800h. Final value 800h corresponds video page 1.
On vgaonly machine -- only slow reaction.
On cga machine -- slow reaction and half address (for odd values of registers: attributes changes with symbols).
On svga_s3 machine -- correct work.
Please post the exact dosbox version, and the config file contents.
wrote:Please post the exact dosbox version, and the config file contents.
My DOSBox version 0.73 (i used also 0.72) for Windows. My system is Windows XP.
My program hs3.com use active display page 1. If you use text_addr.diff and text_addr2.diff you must patch function 5 of INT 10h (select active display page). You must patch also cursor position.
Registers 0Ch, 0Dh (of port 3D5h) values for text modes 80x25 :
Page 0........0000h
Page 1........0800h
Page 2........1000h
Page 3........1800h
Page 7........3800h
Registers 0Ch, 0Dh (of port 3D5h) values for text modes 40x25 :
Page 00h.......0000h
Page 01h.......0400h
Page 02h.......0800h
Page 03h.......0C00h
Page 0Fh.......3C00h
text_addr2.diff includes text_addr.diff, don't use them together.
1+1=10
What exactly can't reproduce?
Ok, now I've found something.
The left column of asterisks also shows up on real hardware VGA but not on real hardware CGA as in DOSBox.
The "slow reaction of scroll" I can't repoduce neither in vgaonly nor others.
1+1=10
wrote:Ok, now I've found something.
The error means on real hardware VGA. A column of asterisks should not be at the left at all on any card. I at first wait for vertical synchronisation, then I change value of the register (video memory start address) and only in the end I put a column of asterisks. The videocard for some reason waits one frame, and then changes the address. I name it as slow reaction (slow response).
