Reply 20 of 27, by robertmo
- l33t++
smartdrv as expected makes the game works with the same regular jerkiness. The only thing it solves is that if sth was already loaded from hdd it is not loaded again, so after making a circle on the walls around the city, the next circle is done almost without any hdd access.
So pianoman72 what you say just doesn't make sense. Have you checked without smartdrv too?
