Ecran noir DOSBox
Reply 20 of 24, by robertmo
and the manual says you should do what?
Reply 21 of 24, by Rombu2010
Manual send to Problems with HP laptop keyboard mapping
I don't understant these solutions, which involve to delete some files, I don't want to do mistakes and to have problems later...
So I was thinking about a solution with shortcuts or modifying the dosbox-0.74.conf
Is it possible ?
Question : is it a problem that the name of the directory of dosbox is "dosbox 0.74 (I mean the empty spaces) ?
Reply 22 of 24, by butterfly
The only thing I have in mind now is a problem I had using the same configuration under XP and Vista and 7. In Vista and 7 when the DOSBox window tried to maximize it got stuck in Vista and had different weird results in 7, included a blank screen in the DOSBox output area. The problem was caused by DOSBox trying to go fullscreen but only if I used ArcadeMenu as launcher.
Reply 23 of 24, by robertmo
What keyboard devices and also what hid devices have you got in your device manager?
Reply 24 of 24, by Rombu2010
Hello,
I finally succeed to programm a file .bat which use
cmd
set sdl_videodriver=windib
dosbox.exe
And I can use DOSBox
So I use this programm .bat instead of the shortcut DOSBox
Thanks for your help !!!
