Games that require MSCDEX exe driver...
Reply 20 of 22, by VirtuaIceMan
World Rally Fever is fixed in new CVS compile of DOSBox thanks to this update:
* MSCDEX sets word on stack to ADAD if it DADA on entry.
Thank you to QBix for looking at the problem, and wd for support too!
Reply 21 of 22, by Friddle
HEY GUYS, I GOT THE FULL GAME WORKING ON WINDOWS XP PERFECTLY. NO HACKS, NO PATCHES AND NO SOFTWARE OF ANY KIND REQUIRED.
SINCE THE DEMO IS KNOWN TO WORK PERFECTLY, ALL I DID WAS DOWNLOAD THE DEMO. WHEN IT WAS TESTED, I FOUND THE DEMO WORKED IN THE WAY EVERYONE SAID IT WOULD. SO THEN I THOUGHT "HEY, IF THE DEMO WORKS BUT THE FULL GAME DOES NOT, THEN THE DEMO VERSION SURELY HAS A FILE THAT THE FULL GAME DOES NOT - WHICH ENABLES IT TO WORK"...
SO, WHAT I DID, WAS SIMPLY INSTALL THE DEMO, AND THEN COPY ALL THE FILES FROM THE 'FULL GAME' TO THE SAME DIRECTORY AS THE DEMO, REPLACING ALL THE DEMO FILES WITH THEIR 'FULL VERSION' DUPLICATES, BUT 'LEAVING BEHIND ALL THE FILES THE FULL VERSION DID NOT HAVE'.... THE FULL GAME WORKED PERFECTLY AFTER THIS IN DOSBOX!!!
THE BLADE RUNNER
