Reply 20 of 23, by gsaunders
Oops... found it.
Hunter... Thanks for the link.
It lead me to the emucr site:
http://www.emucr.com/search/label/DOSBox
And from there I pulled the DOSBox SVN r3663 and will test it.
Reply 21 of 23, by gsaunders
Does it start in an unmodified SVN build?
Yes... it loaded with DOSBox SVN r3663 (if that is indeed the latest SVN build)
Reply 22 of 23, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
So it's probably something with device attributes or the INT17 function. Would require further investigation.
1+1=10
Reply 23 of 23, by gsaunders
<< So it's probably something with device attributes or the INT17 function. Would require further investigation. >>
Since we have a workaround we don't have to pursue this... but if you want to investigate further then I'll be happy to provide any info I can.
