Reply 20 of 25, by luckybob
- l33t++
wrote:Not like Dell. At least some of the computer makers used standard ATX power supplies, motherboards and cases.
That's a bit of a selective memory, there. Most of the midrange/highend Dell systems were pretty close to standard during the late Pentium - PIII era. There was the different power supply pinout, but in their tower machines it was still a regular ATX size and was pretty easily adaptable to a standard PSU. People seem to forget about those systems, though... most of the Dell talk around here centers on Optiplexes, which have never been standard and were never intended to be upgraded much (though you can still do quite a bit with them, even so).
Dells are also pretty good about CPU upgrades... You can even slap a Tualatin (with adapter) in most of their PII/PIII machines and it'll run without complaint. Compare that to the Compaqs which will usually complain if you even try to use a later stepping of chip from the same architecture.
That was because of the chipset more than anything else. the 440BX chipset was probably the best thing to ever come out of intel. And it wasn't until the 815 and the p4 did it get replaced.
Slot 1/S370 was such a long and successful platform its silly. And it started with the pentium pro. There exists (its rare) a socket 370 to socket 8 converter that allows you to run 66mhz celeron chips in a pentium pro motherboard. hell, the p-pro overdrive is nothing but a p2 with better cache! I have a pair of pentium pro to slot one converter cards, And they will post in just about every slot 1 system I try. Most however panic and crap the bed during post because they dont know how to deal with the p-pro but the boards with the bios support (ex: Tyan S1686) do. Its just the same as the Asus p2b-d, 440bx chipset. designed for the 1st and 2nd generation pentium 2. Turns out with a simple modification to some cleap slot 1 adapters, you can run everything up through the 1.5ghz tualatin. http://tipperlinne.com/p2bmod.html
