Reply 20 of 23, by bailey
- Newbie
wrote:Setting ps1audio=off appears to work around the problem. With the default of ps1audio=auto, ykhwong's build identifies the machine model as a PS/1 through INT 15/C0, and for some reason PoP will not use the MPU in that circumstance. Actually, having the machine identify itself as a PS/1 when using default settings seems like it could cause other problems...
Wow, thank you. You're amazing!
wrote:gosh, don't we have written somewhere to use the official release of DOSBox when reporting bugs ............
You're amazing, too. 😀
